Thread: LED light help!
micah
posted October 19, 2009 12:28 PM |
LED light help!
I installed the 4 led rear lights,,,,but they will not blink on turn signal blinker,,,,they will blink with hazard lights,,,,when i hit the turn signal they just stay lit,,, brake lights and all work,,,these are brake and turn signal lights btw with the correct 3 prong plugs,,,hmmm help please
gborch
posted October 19, 2009 01:13 PM |
leds
The lights will not flash due to the extremeley low voltage draw. If you have a strong flasher it will hyper flash or the unit will sense a low draw and do a hyper flash like one is burned out.. But due to your stock flasher unit these lights do not draw enough current to perform with the flash. You need to get a electronic flasher unit.
Good luck.
let us know how it goes
micah
posted October 19, 2009 05:05 PM |
thanks,,,i did find a relay in town,,,,gonna connect it soon and find out,,,
spokanerxdude
Less cubes... More balls
posted May 25, 2010 04:59 PM |
micah how did the relay work out thinking of doing the same to my repu
509-998-9024
mattraver
posted May 25, 2010 08:43 PM |
in line resistor , thats how i got my turn signals to work on my motorcycle.good luck
posted May 26, 2010 09:26 AM |
I put some leds on my f-450 work truck. I had to add a load equalizer to each light. Got them at Kragen.
1974 Mazda Repu
1986 Yamaha RZ 500
1988 Yamaha YSR 50
1991 Suzuki RGV 250
1992 Yamaha TZR 250 SP
1996 Aprilia RS 250
2003 Ford F-450 6.0 Diesel
2004 Mazda RX8
2006 Yamaha Banshee
2014 18' Eclipse Toy Hauler
top1usa
posted May 12, 2011 12:01 AM |
quote: I installed the 4 led rear lights,,,,but they will not blink on turn signal blinker,,,,they will blink with hazard lights,,,,when i hit the turn signal they just stay lit,,, brake lights and all work,,,these are brake and turn signal lights btw with the correct 3 prong plugs,,,hmmm help please
Where did you get these LED's light at? How much were they? Any 411 would be great.....THANKS A LOT!
TIM
74' Mazda Repu-Flare
yellow
85' Toyota ae86-Red-SOLD
88' Toyota ae92-Gray
14' Toyota Prius
