Index > Body Exterior > Thread: wiper assembly nuts
mwpayne1
posted March 06, 2007 07:20 PM
Edited By: mwpayne1 on 6 Mar 2007 19:22
Wiper assembly nuts
If one of you kind fellows gets a chance, take a look at your trucks' wiper arms on the outside. What I need to know is, are there nuts/washers that hold the assembly down, then, above that, the arms themselves attach?
Reason being my truck didn't have them (or I lost them two years ago).
I have the arms, but I can't find the correct size 12mm (I think) nut to hold the thing against the cowl itself. I found the correct nuts for the arms, the assembly is being a pain.
I've scoured lowes, HD, etc with the entire assembly in hand, 12mm seems right, but the threads themselves are funky.
posted March 07, 2007 08:06 AM
Edited By: klaus42 on 7 Mar 2007 08:08
Rotary Pickup Parts Catalogue...:
...exploded view, Page 218 -- Windshield Wiper:
(As listed, in order of assembly onto the wiper shaft --PER SIDE--)
0259 87 134 Nut (2) *One on top of the other, apparently!*
1823 67 352 Bush
1823 67 351 Bush
0305 87 906 Washer, Cap
0212 66 372 Nut, Decoration
0212 66 371 Cap, Rubber
0223 66 371 Nut
--Note that you still have to decide in between what items in this stack the actual wiper arm goes; the exploded view fails to show this detail--
Hope this helps!
(RE: 'Funky' threads : SOunds like a different thread pitch...?)
mwpayne1
posted March 07, 2007 03:21 PM
Klaus, you da freakin' MAN! I'll check with the mazda dealer to see if they can get that stuff.
Funky=different pitch, same meaning to me..:)
posted March 07, 2007 04:28 PM
http://www.nutty.com/methexnut.shtml
0.016127824783325 seconds processing time
