Index > Body Exterior > Thread: bed dimension?
posted July 08, 2002 07:11 PM
bed dimension?
is the REPU bed the same dimensions as ford courier?
posted July 14, 2002 07:59 AM
I have never actually measure one. But if it were different I would be really surprised. The beds shared front wall supports and fender wells. The end supports were drilled for different lights for the 2 models but they are the same. And the tailgate interchanges between the two also.
for it.
85' GSL-SE
83' GSL
posted July 14, 2002 10:23 AM
The Courier and B1600 have narrower rearends and need fenderwells closer together. This means the REPU has more bedspace between the inner fenders than the the boinger models. I can fit a twinsize matress in mine just fine. :)
posted July 22, 2002 08:13 PM
verified that width is approximately the same, but REPU bed is shorter than a long bed courier by about 9 - 12 inches. might be same as short bed?????
Rotor
certifiable rotorhead
posted August 23, 2002 01:26 PM
Edited By: Rotor on 23 Aug 2002 13:28
I believe if you measure the rear end of a B series/Courier, and the rear end of a REPU, you'll find they are the same width. The difference in track width is due to the REPU having more offset in the wheels, and the wider wheels that came on the REPUs.
ROTOR
0.018018007278442 seconds processing time
