Thread: stupid headlight ?
BadAssRX-7
posted February 07, 2007 11:04 PM |
stupid headlight ?
ok i looked all over online at the parts stores and i cant get a # on the dam headlight. anybody? im trying to see if there is a kit i can buy to change from a sealed beam to the replaceable element style. I have done this on my b2000, b2200 and all my 7's the lighting is SO much better
posted February 11, 2007 02:41 PM |
Headlights
Pretty sure you can still get 5 3/4" halogen headlamp conversion kits, e.g. Hella. Should be about $100 for a pair. Use a relay, more current draw.
Call me if you have no luck
Bruce Toski
954 583-4191
repu510
posted February 11, 2007 06:07 PM |
another upgrade you may want to consider is the wiring for the H4 lights. Hella makes a kit (that I've found particularly hard to find) and Painless Wiring (which is pretty expensive). Both come w/ larger gauge wiring, relay, and direct connection to your battery. Painless is sold at Summit although I haven't found anyone much cheaper.
posted February 12, 2007 08:57 AM |
headlight
summitracing.com sells the headlights and replacable element. Matrix is the co that makes the headlight.
BadAssRX-7
posted March 07, 2007 10:49 PM |
so what is the light model or style # ? ill check at summit as they opened the warehouse about 30 miles from me :)
