Index > Body Exterior > Thread: 77 wiper motor removal
tankkira
posted November 18, 2006 12:26 PM
i am having trouble removing my wiper motor on my 77 repu, i have removed the for bolts securing the motor to the mount, but do not know how to remove the linkage from the motor. if any body knows how i would appreciate this.
thanks luke
rotary power
posted November 19, 2006 08:15 PM
Wiper motor removal
I just took one out of my 77, so here ya go.
1.Take off both wiper blades.
2.Take off the nuts on both side holding the wiper shafts up through the cowl.
3.Disconnect the wiring plug from the motor
4.Remove the hardware secureing the motor.
5. With the motor loose, push the wiper shafts down inside the cowl, move the motor and mechanism (linkage) around to free the hood release cable, continue working the motor and attached wiper arm linkage until you have it worked loose and free.
6.Now you can remove the motor from the mechanism.
7 Before starting all of this operation do fault check your wiper motor to make sure it isn't a fuse or the wiper switch.
8.Installation will be in reverse.
9. Not how the shafts are installed in the brass bushings, if you plan on further dis-assembly.
10. note the plastic bushing that centers the brass bushing in the cowl hole
Manteca Mazda Asylum
tankkira
posted November 19, 2006 08:36 PM
thanks for the very detailed info i am going to come home tomarrow after work and try this. i think the motor is pretty fried it starting going real slow then stopped and the motor was very hot and smelled burnt. i really appreciate the info i will let you know how it works out.
thanks luke
rotary power
posted November 20, 2006 12:20 PM
wipers
When you remove the motor, it has a "C" clip and wavy washer like the wiper shafts, make a note of how it goes together.
tankkira
posted November 25, 2006 07:05 PM
trouble installing new motor
i have received my rebuild motor but am having trouble getting the ball on the motor to push into the arm linkage . i checked and the new motor works great just need to install linkage and the motor to backing plate. any info on how to get the linkage to pop in i would appreciate. thanks luke
rotary power
posted November 28, 2006 12:05 PM
77 Wipers
"Ball on the end"? it should have a shaft with a wavy washer and a "c" clip that looks just like the two at the wiper arms. If you still have you old motor see if the two are idendtical, if not that's the problem, or the little bearing thats riveted on the lingage might be what your looking at.
tankkira
posted December 02, 2006 07:28 PM
hey man, i already have put the ball and waving washer on the new motor put i cant get the ball to pop into the arm linkage. i hooked up the motor and it works but i dont want to force anythting. thanks for all your help. luke
rotary power
tankkira
posted December 03, 2006 02:01 PM
i just figured out that my problem is that iam trying to replace this with the linkage still in truck. i probablly would have a easier time removing it with it out of truck. it almost comes out put it hits the hood release cable. how do i remove this? any info would be greatly appreciated. thanks luke
rotary power
posted December 04, 2006 07:31 PM
77 Wipers
When you push the linkage down thru the cowl you can move it around to let you move the hood cable out of the way. Then bring the whole wretched mess out from under the cowl.Now disconnect the motor from the linkage. Installation should be in reverse.
tankkira
posted May 19, 2007 11:37 PM
finally got my wipers back in!!!!!! thanks for everyones help with this. funny now ther in and it is summer!
rotary power
0.024139881134033 seconds processing time
