Index > Body Exterior > Thread: Dangit..more rust holes..
mwpayne1
posted July 15, 2006 08:38 PM
The very back between the bed and the cab had accumulated a ton of leaves and dirt. I thought initially it was just surface rust, but after wearing out three wire brushes, then sandblasting, I find that there are dozens of rust holes...tiny ones. The biggest is maybe BB size, most are much smaller. Can I just rust proof with Zerorust, then maybe fiberglass over? Way too many to weld I think. What would y'all do?
posted July 16, 2006 05:19 PM
I'm not the expert...
...but, I suppose it all comes down to whether or not an 'invisible' area matters, in terms of being restored to 'visible' (invisible repair) standards.
If you're creating perfection, don't stop now!
If no one will ever see it, and you can rest easy knowing what's there... patch it up, and paint over it.
mwpayne1
posted July 18, 2006 07:36 PM
My neighbor suggested a product called 'metal to metal'. I guess I'll use that,prime, epoxy, then paint. It's a spot where no one will see, anyway. Thanks.
0.016611099243164 seconds processing time
