Index > Body Exterior > Thread: What's our options for body bushings and bolts?
posted December 20, 2004 08:14 AM
I just can't mount the body with all my used squished, cracked and hard bushings or the rusted bolts for that matter. I haven't tried Mazda. Probably won't like their price if they do have them. I figure I can reuse the washers.
Here are the numbers I have so far, they are 74 numbers, I just happen to have them at work, I dont know if the 77 manual reads any different:
0603 53 920 Rubber mounting, lower
0603 53 950A Rubber no 3, mounting upper
0603 53 070 rubber mounting, lower
0603 53 004A Bolt no 1, mounting
0614 56 575A Bolt, mounting
Anybody been successful at obtaining them?
STEVEN
posted December 25, 2004 10:37 AM
I have a 74 parts catalog. Someone has crossed those numbers out and made the notaion "deleted" Along side. I would assume this means that Mazda possibly has changed the numbers.
74 repu
posted December 25, 2004 11:13 AM
Yea, I got that on mine too.......
I talked to mazda, and they have NLA for all the parts I listed. No superseded parts either.
I did find a set of Energy suspension polyurethane pads for a jeep. They fit perfectly and came in a set of 14. I needed 12 for the cab. I replaced the stock shoulder bolts with a set of 1/2" grade 8 bolts, 3" long. I used (2)2" fender washers, a lock washer and 2 lock nuts. I also refinished and re-used the stock flanged washers that go on top of the lower bushings, under the frame flange.
My system is a lot stronger than stock, so I am happy.
posted December 27, 2004 05:04 PM
For the bed I used a sewer line coupler made of plastic/rubber poly. Got it at Lowes. Cut it up to right size and put a coat of grease on it for good measure and reduce rust liklihood. Got Grade 8 bolts, washers, and lock nuts from Orchard Supply.
posted December 27, 2004 10:05 PM
Sewer line coupler......?
I guess I can't picture it....is it a rubber or plastic tube? or what?
How does it work? Are the bed body lines still in sync with the cab?
0.017482042312622 seconds processing time
