Index > Engine/Drivetrain > Thread: Starter compatibility
posted February 15, 2004 04:11 PM
My starter died. I've been having starting trouble and suspected low cranking RPM...Has anyone else had the same poblem? Anyway, my '77 has a 1st gen rx-7 5-spd. and I was wondering if a 2nd gen rx-7 starter will work? Thanks.
posted February 15, 2004 08:50 PM
Pretty much a yes....
as all starters from 74 - 86 are interchangable including manual tranny N/A starters from 87 - 91.
So the answer is probably yes as long as it is not a TII or Auto 87+.
posted February 16, 2004 01:03 AM
No auto starter will work on a manual tranny, unless I'm smoking something.
posted February 16, 2004 07:23 AM
Yes, your correct, I meant to say....
All Manual Transmission starters, I was a bit sleepy and working on several things when I responded.
No autos work with M/T's.
Your not smoking anything....
posted February 16, 2004 07:45 AM
I've got one....
.... you can have sparky. It's off a second gen. manual. Give me a call.
1974 Mazda Repu
1986 Yamaha RZ 500
1988 Yamaha YSR 50
1991 Suzuki RGV 250
1992 Yamaha TZR 250 SP
1996 Aprilia RS 250
2003 Ford F-450 6.0 Diesel
2004 Mazda RX8
2006 Yamaha Banshee
2014 18' Eclipse Toy Hauler
posted February 16, 2004 08:41 AM
Thanks Max.
posted February 16, 2004 10:32 AM
Thank goodness...
... I'm not the only one around here who sometimes posts while sleepy! :b
posted February 17, 2004 09:41 PM
Something interesting.
I changed the starter andf went to turn over the engine and had a real bad grinding noise. It turns out that the drive gear on the replacement starter had 9 teeth while the original starter had only 8. I was able to change out the drive gear assembly onto the new starter. Truck starts much better. Thanks again for the starter Max.
0.02314305305481 seconds processing time
