Thread: 13b GTU will it work?
WVoigt
posted October 12, 2003 06:07 PM |
How much trouble would it be to put a 1990 GTU in my REPU?The engine comes with the wiring.It has 90k miles on it. Besides changing the fuel pump and front cover. What esle is there to change?
1974 Repu
1973 Courier
1989 Car Dolly
posted October 13, 2003 09:12 AM |
Unsure of all the specifics, but:
Oil pan, and motor mounts will be needed. You'll need to use an earlier trans. if you wish to retain the 'proper' shifter location as well, in order to avoid cutting out your floor...
posted October 14, 2003 07:37 PM |
if you change the oil pan, you'll most likely need to change the oil pickup tube
86-92 13b
70's 13b
posted October 17, 2003 02:32 PM |
You say engine has the wiring, does it have the ECU and ignition coils? As far as bolting in that is no problem, front cover takes care of that. There might be some custom work getting the oil metering taken care of, if I remember right that is mounted on the front cover and the REPU setup is different from the '90 rx7. I just disabled the OMP when I put in an '86 rx7 motor, premix isnt really that big of a hassle.
WVoigt
posted October 18, 2003 09:30 PM |
Thanks Guy's
I got the engine,ecu,coils and the wiring harness.I'm missing the wiring from the Ecu to the coils ( No big deal?) I'm cleaning it up this weekend.The metering valve may be a problem? Premix would work but the Ecu will not work without the metering valve.I will let you know how it goes.
Thanks Again
Bill
1974 Repu
1973 Courier
1989 Car Dolly
WVoigt
posted October 22, 2003 07:30 PM |
Metering Valve Problem
The metering valve will not mount on a repu front cover.
It is required for the ECU to work.
Any idea's?
1974 Repu
1973 Courier
1989 Car Dolly
posted October 23, 2003 02:21 PM |
Maybe contact mazdatrix and see if they have an adaptor, if not at least I am sure they could tell you how to get through the OMP issue.
They were of great help when I dropped in the '86 rx7 motor into my REPU. Nearly every question I had about mixing and matching different rotary parts they were able to answer.
