Index > Engine/Drivetrain > Thread: ignition switch 76 repu
Thread: ignition switch 76 repu [' This thread is 2 pages long: (1) 2 ']
cactuspunk
posted July 29, 2003 07:07 AM
Edited By: cactuspunk on 29 Jul 2003 12:31
Ignition switch for 76 repu
Does anyone know how I can obtain a working ignition switch for a 76 repu? I need it from the 3 plugs up to the key switch. Or is there a way to make the truck start and stay running without it? Any suggestions?
dirty south...
straightrepu
posted July 29, 2003 11:15 AM
try mazda
part number 3775-75-980, costs anout a hundred dollars. It
will probably come from japan, currently its out of stock in the US warehouses.
74 restorepu
cactuspunk
posted July 29, 2003 12:30 PM
thanks, i'll try to order that
dirty south...
posted July 29, 2003 04:21 PM
Craig's the man on that sort of info, just be careful about dealership markup. They wanted to charge me $145 here in Orlando. Naples (Florida) was over $200. They thing everything is made of gold down there.
straightrepu
posted July 29, 2003 05:24 PM
he`s right
Sometimes parts can be marked up above mazda suggested list.
For the ignition switch its $101.50.
74 restorepu
posted July 29, 2003 05:32 PM
That's crazy spendy!!!
Not that it wouldn't be worth it, for a NOS mazda part, but still... Ouch! Yes, it is possible to bypass your entire ignition cylinder very easily... or, it might still be possible to make yours work by squirting in a small blast of 'Cramoline DeOx-it' type contact cleaner... Also noteworthy if on a budget: Early KIA sportages used an identical ignition cylinder (!)...only the key doesn't look quite right... And what about the Ford courier unit? There must be a cheaper way...(though not likely better).
cactuspunk
posted July 30, 2003 05:23 AM
Thanks for all the feedback...I called the Mazda dealer in Atlanta yesterday and they said they would order it, but that it may not be available. They also were honest about the price, they said it would be $101. Thanks again all...
dirty south...
cactuspunk
posted July 30, 2003 08:11 AM
If you don't mind and sorry for my inexperience, but how would I bypass the ignition cylinder?
dirty south...
posted July 30, 2003 10:42 AM
Edited By: brad on 30 Jul 2003 10:44
with an ignition flip switch and a push button for starter
http://www.longacreracing.com/catalog/item.asp?id=446&catid=13
http://www.longacreracing.com/catalog/item.asp?id=444&catid=13
I just did this on the racecar. get a multimeter and check each wire going into the ignition switch when the ignition is off, on, and starting. That way you'll know which wire has + power all the time, which get switched on when the car is on, and which triggers the starter solenoid.
Then wire it up!
straightrepu
posted August 01, 2003 11:35 AM
its coming
checked on your ignition switch, looks like you should be getting it next week.
74 restorepu
cactuspunk
posted August 01, 2003 12:47 PM
awesome...is this the guy i talked to at jim ellis? thanks again for your help...
dirty south...
straightrepu
posted August 01, 2003 01:12 PM
different guy
I`m the one that gave you the part number, I work in a mazda
dealership in california. As far as I know I`m the only mazda parts employee thats a member of this forum.
74 restorepu
cactuspunk
posted August 01, 2003 01:30 PM
ok it's all clear now...I knew you were the one that gave me the part number, but I was confused when you said it was coming. The guy at the Mazda dealer in Atlanta said he would let me know when it came in and I thought this is too weird that you were the same guy I talked to at Mazda. Anyway, take care.
dirty south...
straightrepu
posted August 08, 2003 05:44 PM
did you get one?
checked the availability of the switch today, its no longer avaiable. Where you able to get the last one? A lot of parts I`ve ordered lately come up unavailable after I get it in.
74 restorepu
cactuspunk
posted August 08, 2003 08:11 PM
i haven't gotten it yet. i'll let you know if i do or not next week.
dirty south...
buito
posted September 17, 2004 04:52 PM
ignition switch
I own a 1976 Repu. I can remove the key from the ignition and it remains on. I move the cable harness under the steering column and the engine is shut off. Sometime while driving and I hit a bump or pothole the engine is shutdown. Any ideas? Has this happened to anyone before? Any suggestions for fixing this?
posted September 17, 2004 08:19 PM
Check to see if a connector has backed out of the assembly and making end contact only. That would do it, and I have seen this on an RX3, so I know the connector can do this. Mine shut off the coil resistor bypass circuit, and the car would not start with the starter, but fired up when pushed. Very hard to find....About drove me crazy for a week!
posted September 18, 2004 09:14 AM
Ah, the 'joys' of aging wiring!
Could also be a break in the wire within the insulation... tho perhaps not as likely as a loose/corroded connection. The key coming out with the motor running is not uncommon... I wouldn't worry too much about that part.
...nothing like having to do the 'wiggle test' on various bits of wiring to 'cure' 'mystery' electrical issues...
cactuspunk
posted September 20, 2004 05:54 AM
I had the same problem of the engine shutting off when I hit a bump. I found that the wires behind the passenger seat going out to the battery had corroded. Some new wires and some wire cleaner spray fixed it...
posted November 11, 2004 08:41 AM
76-77 ignition switch
If anyone still needs an ignition switch for the 76-77 REPU I found two and posted one up on ebay:
see: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7934171610
Bruce Toski
954 583-4191
0.0401930809021 seconds processing time
