Index > Engine/Drivetrain > Thread: Gears for Rearend
Shefron
posted January 25, 2003 11:34 PM
Gears for Rearend
I was wondering what are the gears in the rearend of a 87 Mazda B2000 extend cab. The truck came with a 5 speed manual still I swap in a V8. But I seem to be getting 6 miles to the gallon and we are thinking its because of the gearing.
perferable
1. Where can I get some taller gears for the rearend?
or
2. What is a rearend that will fit in from another vehicle that could handle a stock V8 and needs only minor mods to fit.
Save my gas milage....
87 Mazda B2000 Cab plus
chevy 350 V8
4-Speed Saginaw
dodge48
They call me the "Anti-Honda"
posted February 12, 2003 04:57 PM
Edited By: dodge48 on 13 Feb 2003 16:55
I cant be sure but it might be 4:11 gears. if your running a 4 speed non overdrive with the 4:ll gears, well, theres your problem. thats probably a 6 lug pattern right? if you want to do a swap on it to put a chevy s-10 rear end in it and front in conversion to an s-10 taht would be good. lot of trouble though. It would allow you to have drop spindles and more wheel choices. Just depends on how far you want to go.
        Click here to send dodge48 an AIM message.
posted February 12, 2003 10:08 PM
What is your RPM at 60MPH or 100KMH?
posted February 13, 2003 07:23 PM
If I remember correctly, the mazda rearend was a third member type, similar to most ford rear wheel drives. It is probably outsourced by mazda from a company in japan (or even here!)that makes lots of rearends. Check with your knowledgeable wrecking yard people and see if they have a cross fit book. You might get lucky!
posted February 13, 2003 09:27 PM
People have said the REPU diff is like the common ford 9 inch. They look similar, but I've never compared them side by side.
shefron
posted February 14, 2003 01:19 AM
Well I have found the mod for the saginaw 4 speed that I have in it currently.
http://www.chevytrucks.org/tech/overdrive.htm
I'm hoping this will solve the rpm problem since it almost makes it a 8 speed but first I would like to find more info on the mod.
dodge48
posted February 14, 2003 07:43 AM
wow that mod that guy did was really, really smart. i cant beileve no one had thought of that before. That opens up some new possibilites for using an older 4 speed instead of trying to find a new overdrive like a t5 or t56.
Always remember in life: If at first you don’t succeeded, sky diving isn't for you.
0.021772146224976 seconds processing time
