Index > Engine/Drivetrain > Thread: Transmission mount
spokanerxdude
Less cubes... More balls
posted May 22, 2015 09:21 AM
Transmission mount
So here is my problem, I'm putting a stock 76 repu tranny into a 74 repu and can't get things to line up. Is there a difference in the mounts between the years? The mount is to far back kinda like an FB tranny, I even tried a modified for an FB mount and it won't work eather, holes are to far back. I'm kinda stuck in the middle, LOL. For now I'm just going to elongate the holes in the FB modified mount to get things going
509-998-9024
posted May 22, 2015 05:51 PM
Sometimes ya just gotta wing it.
posted May 22, 2015 10:03 PM
Edited By: nwaco on 22 May 2015 22:04
It should fit...
If the transmission is a ribcase with separate bell housing, it should fit. Are you sure it is an original 76 tranny?
spokanerxdude
posted May 23, 2015 04:29 AM
yup, LOL you do.
509-998-9024
spokanerxdude
posted May 23, 2015 04:42 AM
I beleave so, it was in the 76 when I got it and the mount fit in that truck. Is the bottom of the stock tranny slanted to one side instead of flat?
I also saw somewhere that the gear oil is and old style, because the new stuff eats the syncro rings, if so what type oil am i looking for? Just something I read recently and can't find again.
509-998-9024
posted May 26, 2015 08:58 AM
The old school and 1st gen rx7 transmissions use brass synchronizer rings and their oil spec is GL-4. Newer gear oils eat brass. So you want something that is specifically GL-4. Not one that is 'compatible with newer and older transmissions'. It is hard to find, but:
Sta-Lube makes a GL-4 oil, you can get it from NAPA auto parts. Also Redline Oil makes a MT-90 that is phenomenal.
spokanerxdude
posted June 01, 2015 04:51 AM
Edited By: spokanerxdude on 1 Jun 2015 04:54
Thank you Brad, I knew there was something about the gear oil just couldn't remember the spec for it.
As for the tranny mount had some time to look at both trucks this weekend and noticed that the 76 has two sets of mounting holes on the frame mounts, so I'm assuming that one is for the 5 speed and one is for the 4 speed. Anyway the 5 speed is 3.5cm further back and the bolts(tail shaft) hit on the tranny cross member so using the Rx 7 modifed cross member won't work; did some measuring and put together a plan to build a mount. Now it's just a matter of time and money.
509-998-9024
0.029536008834839 seconds processing time
