Index > Engine/Drivetrain > Thread: flywheel #2
Thread: flywheel #2
bosozoku
posted December 07, 2013 09:04 PM
flywheel #2
my 1974 repu flywheel has a #2 stamped on the back and has 9 bolts for the clutch. my question is this. i want to upgrade my transmission to a TII trans. would i be able to use a GSL-SE flywheel counterweight? i was looking at mazdatrix site and they list the counter weight from 1976-1985. are 1974-75 rotors different?
posted December 08, 2013 09:20 PM
Yes, you can use a gsl-se rear counterweight with any REPU rotating assembly. The weights of the rotors are the same. The compression got a little higher with the gsl-se.
0.01628589630127 seconds processing time
