Index > Engine/Drivetrain > Thread: Clutch? Need help please.....
JD466
posted May 13, 2013 05:07 AM
Can anybody on here tell me if the clutch's in the early RX7's (pre-84) fit the REPU 13b trucks? Specifically a 1977 with the 5 speed manual trans? The reason I am asking is that I am having a hard time locating a 8 7/8" clutch for this truck. Autozone and Advance Auto doesn't list a clutch that big for the 1977 Mazda Rotary pickup but that is exactly what I have pulled out of it, and it appears this is the size that came in the early RX7's. I know zilch about interchangability with the early Mazda so hopefully someone on here can clue me in. On a side note there is a possibility that this truck will be going up for sale when it is done. More info to follow.....
fliboyz6
great
posted May 13, 2013 07:47 AM
from my research i have found that it is the same clutch as the early 7's ad well as most of the mazda vehicles from the time including ford couriers... and on that note i would make sure to buy a high quality clutch... i just had mine scatter in my driveway
JD466
posted May 13, 2013 09:05 AM
Thanks,that is what I was hoping to hear.
posted May 29, 2013 11:27 AM
You need to change the flywheel to a GSL-SE. Then any 225mm disc and pressure plate from 83-88 can be used. You're welcome.
Actual differences:
REPU flywheel is 30 pounds, weird step disc and odd 9 bolt pressure plate. Good luck finding replacements.
GSL-SE flywhweel is 26 pounds and still plenty heavy enough for these trucks. Clutch discs and pressure plates are easily found.
Both are in 225mm so no loss of friction area.
0.020048141479492 seconds processing time
