Index > Engine/Drivetrain > Thread: tach cable for a 76 repu help!!!
rotorsport
posted April 01, 2013 09:27 PM
hey guys i just pick up a 1976 repu it clean i just dropped an 85 gsl se 13b in it with a Webber side draft any how its running i don't have a working tach so I'm looking for the cable i know its a Yellow with green stripe but i don't know in with part of the harness its in can someone show me a picture of where i can fine it and if its the right color wire I'm looking for would appreciated it thanks... ps Ive been looking in the forum
jm1fd
posted April 02, 2013 05:19 AM
I've been through the whole main harness on my '77. On my truck it was yellow w/ white stripe. It started at one of the coils, went down to the emissions "computer" then up to the round connector that goes into the back of the cluster. The details as to color and stops along the way may vary since you have a '76, but at the very least it should be present at both the round cluster connector and one of the coils.
rotorsport
posted April 02, 2013 02:12 PM
Edited By: rotorsport on 2 Apr 2013 14:13
Ive looked theres one wire thats just yellow with a female connector i tired it no luck i don't know how to post pictures i have some of the wires. i don't have any stock wires going to coils its wired from ignition switch straight to coils then its bridged from one coil to the other then wired to distributor i have some wires unplugged around the coils but don't know whats what i wonder can i just connect a wire from the coil straight to the tach i just don't know which cable is the one from the back of the tach i can wire it up to then theres this little round silver thing looks like a buzzer or something thats wired to the tach can i bypass that if its a over rev warning buzzer any help i like to keep it original don't want to hook up any cheap aftermarket tack thanks
jm1fd
posted April 03, 2013 05:05 AM
Do you have the wiring diagrams and the shop manual for your truck? The shop manual has the pinout for the round cluster connector, and from there you should be able to figure out what pin to connect to the (-) terminal of one of the coils to get a signal into the tach.
Yes, the silver disc thing hanging off the bottom of the cluster is the rev buzzer.
This should help you as far as posting images goes:
http://www.mazdarepu.com/board/faq.php3#bbcode
rotorsport
posted April 03, 2013 03:03 PM
Edited By: rotorsport on 3 Apr 2013 15:05
yea i don't have the shop manual for my truck i been Trying to find one but no luck i try e bay i look on-line nothing so i was hoping someone can lend a hand. hey thanks jm1fd a lot for trying to help i appreciated it. its hard not having a shop manual but any help i can get is great on my 71 rx3 it was easy because i had all my wiring there and i have a factory manual anyhow ill try posting picture today thanks again...
Xp882
posted April 03, 2013 05:45 PM
http://foxed.ca/index.php?page=rx7manual#repu
Maybe those Manuel's will help?
rotorsport
posted April 03, 2013 11:14 PM
Edited By: rotorsport on 3 Apr 2013 23:15
thanks Xp882 nice site ill check it out here the mess i have so far and heres one of my repu hope you guys can help thanks
jm1fd
posted April 04, 2013 12:48 PM
I don't mean to brag or anything, but the wiring on my truck was a WAAAAAY bigger mess before I cleaned it up. LOL
SO...I just had a look at the 1976 wiring diagrams, and I think I can help you.
Somebody put an electronic distributor on there, and didn't bother fixing the tach wire. Probably because people are simply baffled when it comes to electrical work on vehicles. I should open up a shop doing auto electric work....I find it both easy and amusing, actually.
See all those relays on the fender, forward of the coils? One of those should be the retard relay (seriously, that's what Mazda calls it). It should have a 4 pin connector, and in that 4 pin connector, there should be a terminal that has a green wire with an orange stripe. Pull your cluster out, and you should find the same green/orange wire in the round connector that goes into the back of the cluster.
At this point, if I were you, I would do a continuity test between the retard relay green/orange wire and this wire in the cluster connector to make sure it hasn't been screwed around with and that you have the correct wire.
If the continuity checks out OK, you need to connect that wire to the negative terminal of either of your coils, and you should be set.
rotorsport
posted April 05, 2013 12:29 AM
thanks for all the help jm1fd & Xp882
i got it done i will post some pictures soon i rewired my alternator my ignition switch tach and coils next radio speakers then rims/tires/exhaust. now i need 2 brake light lens and one brake light lens beauty ring so if anyone has them let me know. thanks again,
jm1fd
posted April 06, 2013 03:50 AM
You can get brake light lenses from Mazda, but not the trim rings.
0.023231029510498 seconds processing time
