Thread: Where to get a diff crush sleeve?
crit
Finally REPUing
posted July 01, 2012 08:38 PM |
The original REPU PN shows "no longer available". I can find 84 and up B-series truck crush sleeves are still available, but I've got no idea if they're suitable for a REPU diff. Do you guys have a source?
84 GSL-SE
posted July 02, 2012 02:59 AM |
crush sleeves
I have had trouble finding any in the past.
Will chk again ...
What about taking the old one, compressing it slightly at the bulge area and attempting to return it to the stock length ?
before doing the rebuild ?
just a thought
posted July 02, 2012 03:13 AM |
differential crush sleeve
1854 27 171 REPU #
1757 27 171 Cosmo, RX-4
0305 27 171 B1600
The last number got some hits on the web.
I found a nice pdf at
http://www.mazdamotorsports.com/pdfs/catalog/07_Differential_Drivetrain.pdf
MazdaSpeed lists 5 different crush tubes.
Chk with them, let us know what they have ?
http://www.mazdamotorsports.com/wcsstore/B2BDirect/Motorsports/contactus.htm
One poster said, "0305-27-171 list price is $14.34... at Mazda, and they have tons, well 70."
Not sure if the same ...
Here are some Courier numbers ..
D27Z 4662 A (solid) (have 1)
D27Z 4662 B
D27Z 4662 C
D27Z 4662 D
D37Z 4662 A (crush)(have 2)
Hunter ...
posted July 02, 2012 03:15 AM |
'distance piece'
$14 for the 0305 'distance piece' at World Impex.
http://www.worldimpex.com/parts/mazda-distance-piece_3227465.html
mazdarx605
posted July 02, 2012 05:11 AM |
My pinion seal is leaking on my 74 REPU. Will I need this part as well to repair this leak, or will a new seal be enough? I am nervous doing this job, and may eevn farm it out as axle stuff scares me.
crit
Finally REPUing
posted July 02, 2012 09:36 PM |
No worries on the pinion seal. Disconnect the driveshaft, drain oil, zip the yoke off with a 35mm socket, remove yoke and spacer, pry out the seal with a screwdriver, then work your way back.
84 GSL-SE
