Index > Engine/Drivetrain > Thread: front brakes
posted December 17, 2011 04:16 PM
Edited By: jfaplanet on 17 Dec 2011 16:17
Front Brakes
OK, So I was tired of the unvented disc brakes on the front as well as the difficulty of replacing the pads. So I did a little research, the 86-93 b2200 has vented brakes and is easy to obtain. Only problems are (1) the steering is front steer instead of rear steer, hence move the right to the left and left to the right. Calipers will be in the front but i don't think that will be a problem. (2) the brake lines are a different thread pitch, so you have to get an adapter, RE-Speed sells them. (3) steering again, you need to use your brackets that bolt to the spindles to keep the correct steering geometry.
Other than those small issues it works good, easy to obtain and maintain, as well as better selection of rotors and pads.
Hope this helps someone that might need it. If anyone has any questions, I'll be glad to help any way I can
RepuChalz
aka jfaplanet
MAZDAMARK
posted December 21, 2011 10:08 AM
What parts did you off the donor B2200? Just the spindles and brakes?
94 RX7
89 RX7 GTUs
85 GSLSE
88 323 GTX
1975 REPU
spokanerxdude
Less cubes... More balls
posted December 24, 2011 04:36 AM
Edited By: spokanerxdude on 24 Dec 2011 05:02
It sounds like he just popped the ball joints loose and took the whole spindle with everything on it. Then you just change the steering brakets.
Am I right?
509-998-9024
posted December 27, 2011 02:00 PM
Very Right. email directly if you have any questions or need to see pics.
spokanerxdude
posted December 27, 2011 05:26 PM
Edited By: spokanerxdude on 27 Dec 2011 17:28
I would love to see pic's, I'm sure everyone else would too. If you don't know how to put the pic's in your post send them to me with there captions and I will post them for you.
509-998-9024
paulsrepu
posted January 12, 2012 10:52 PM
I have been reading this thread with some interest. The 86-93 B2200 spindle/hub will bolt right onto a Rotary pickup, the only mod is using the stock steering arm and using a brake line adapter? Because if true, then there are cross drilled rotors for the 86-93 trucks and there are 2" drop spindles as well to keep stock suspension geometry yet lower the car. I would love to see a picture of this modification if someone has done it because I might buy the drop spindles then.
posted January 14, 2012 09:36 AM
I would like to see some pics as well.
1974 Mazda Repu
1986 Yamaha RZ 500
1988 Yamaha YSR 50
1991 Suzuki RGV 250
1992 Yamaha TZR 250 SP
1996 Aprilia RS 250
2003 Ford F-450 6.0 Diesel
2004 Mazda RX8
2006 Yamaha Banshee
2014 18' Eclipse Toy Hauler
MOTOMISFIT
posted February 02, 2012 07:50 PM
I'm very interested also...pics and or a how to would be great:)
spokanerxdude
posted February 09, 2012 05:19 AM
Thanks jfaplanet for the pic's I'll post them in a day or so. This spring when it's over 50ish & I have cash I'll try and put together a wright up on this, if someone else can get too it before me please do it.
509-998-9024
pete19964
posted February 14, 2012 01:00 PM
brakes
hey allen when are you going to post those pics
thank peter19964
spokanerxdude
posted February 15, 2012 04:02 AM
I'm trying to get them on my website so I can connect to them here. As soon as I figure that out I'll get them on here.
509-998-9024
spokanerxdude
posted February 23, 2012 04:55 PM
B 2200 To Repu Brake conversion pic's
509-998-9024
jm1fd
posted August 12, 2012 04:41 PM
I finally found a self service yard with several B2200s, and got a pair of hubs this weekend. I'm looking forward to getting them installed on the truck. First gotta make sure they fit alright with my Volks.
jm1fd
posted September 09, 2012 12:08 PM
So....I just test fit my B2200 spindles on my REPU. I wasn't happy with the way the lower ball joint interfaced with the B2200 spindle.
The B2200 hole is way bigger, and the taper doesn't even come close to fitting the way it should. Not happy with it since it is a big safety item, I'm afraid over time it will waller around and cause a big problem eventually.
MAZDAMARK
posted September 22, 2012 12:34 PM
Wonder if B2200 ball joints would be an option?
jm1fd
posted September 27, 2012 04:42 AM
I thought about that.
Looked at the pictures of 'em on RockAuto and it was a definite no-go for the lower. REPU lower mounts with 3 bolts, the B2200 joint mounts with 4 bolts.
The upper has a slim chance of working...they both attach with 3 bolts.
spokanerxdude
posted October 04, 2012 06:20 PM
Edited By: spokanerxdude on 4 Oct 2012 18:31
Not sure these would work but had to throw out the following ideas.
Four things:
1. Looking at the lower ball joints, could you just drill two holes for the B2200 Ball joints.
2. Is it possible to replace the stock lower control arm with the B2200 lower control arm.
3. Now, to throw another wrench in the mix, how hard would it be to put the whole B2200 rear end with the disk brakes intact,
4. and is it easier to put a LSD in the B2200 rear end.
509-998-9024
REPUferd
posted April 07, 2013 12:47 PM
Any updates to see if the b2200 control arm works?
posted April 07, 2013 05:43 PM
Edited By: Brad on 7 Apr 2013 17:50
http://www.mazdarepu.com/board/viewthread.php3?FID=8&TID=194
Doesn't say anything about the control arms.
""I had a buddy that did put later model B series vented rotors on his REPU. He swapped the entire spindle/brake assembly to his REPU. He did have to mount the right sppindle on the left side, and vice-versa. He said it stopped great, and drove fine, but I wonder about the steering geometry of such a swap. I'd think it might do funny things to bump steer, roll steer and Ackerman.
0.035552024841309 seconds processing time
