Index > Engine/Drivetrain > Thread: Dash Lights On?
repufever
posted September 09, 2011 07:35 AM
Dash Lights On?
Ok, guys. I pulled my 4 port out to rebuild (trucks been sitting and she smoked like you would not believe around 4K) and tossed in a S3 13b 6 port motor to get her back on the road. Tossed in on a DCOE45 for fuel and she is back up and running.
The problem is right now the dash lights are staying on and my battery is not charging. Swapped out regulators with my 79sa and did not fix. Pulled fuse block and cleaned it, pulled regulator plugs and cleaned.
Right now im at a loss. Also for some reason the wipers dont work. Headlights do, fan does, turns do, horn does, etc....
Any help? Anyone had this before?
Thanks
77 Repu
Yes, I have a rotary problem!
IN TN?
        Click here to visit REPUFever's homepage.
posted September 09, 2011 09:44 AM
Definitely suggest upgrading old external regulated stock alternator with s-4 or s-5 rx-7 alternator. These are internally regulated. Great mod to do.
http://www.rx7club.com/attachment.php?attachmentid=170065
http://
http://www.rx7club.com/attachment.php?attachmentid=199213
http://www.
These were very a big help figuring it out. Had to install a jumper on the 6-pin connector to the external regulator.
spokanerxdude
Less cubes... More balls
posted September 09, 2011 11:19 AM
Here is another options.
http://www.rx7club.com/showthread.php?t=504471&highlight=cs130
509-998-9024
repufever
posted September 09, 2011 12:16 PM
yes guys those are great upgrades that most of us do asap.
before I start swapping everything over I want to correct the issues I have now.
I might end up back all stock once motor is done with one exception and that is a electronic dizzy and a Yaw Carb.
We will see as all that is down the road......but really liking the 20B swap with an automatic tranny
IN TN?
repufever
posted September 09, 2011 01:50 PM
Edited By: repufever on 9 Sep 2011 13:54
ok, swapped out alts, and regulators. Still nothing so started at alt and traced back to fuse block. Found one terminal that is loose. Added zip tie and wow the dash lights are gone!
http://www.rx7club.com/showthread.php?t=968960
3 days on this and the stupid fuse block was the problem!!!!! I want to punch the engineer in the face!
IN TN?
posted September 09, 2011 09:07 PM
I HATE the fuse block assembly these trucks have. I installed a custom relay box with blade fuses on dedicated circuits because i was sick of poor connections on the buss fuses. I also upgraded to electronic ignition...DLDFIS, great upgrade. The main purpose of my wiring mod was to remove amperage out of the ignition and combo switches and get rid of the fuse block. A real pain but great way to really understand the truck wiring.
posted September 12, 2011 03:20 PM
Somewhere in Japan there's a little retired MAZDA electrical engineer laughing his ass off!
0.023482799530029 seconds processing time
