Index > Engine/Drivetrain > Thread: Carb info
Thread: Carb info
eldudo1981
posted September 05, 2011 12:30 PM
Carb info
What's up guys.
I am going through a pain in the ass rebuild of my stock Hitachi carb. Luckily I have a few Mazda rebuild kits to make to happen, but this thing is fighting me. Looking to upgrade to a newer carb.
I have heard that some people run the Nikki, the question that I have is what do you need to do to convert the Nikki to run a 13b? I would guess that the jetting would need to be larger for the bigger engine.
If anybody is running a Nikki on a REPU let me know.
repufever
posted September 09, 2011 01:57 PM
I am planning the same thing but I will be running a paul yaw modded nikki so should be fine.
Have to tap the factory intake for the nikki to bolt to it but I think it should be fine.
Yes, I have a rotary problem!
IN TN?
        Click here to visit REPUFever's homepage.
eldudo1981
posted December 07, 2011 06:21 PM
Anybody know a part number, or where to get the little brass bleeder that regulates the vacuum to the secondaries? I broke mine in half the other day.
The entire thing was filled with solder. I know some guys solder the end of it so it doesn't bleed vacuum into the car body but is the entire cavity supposed to be plugged up?
Klaus45
On two wheels
posted December 08, 2011 07:13 PM
RE: Vacuum Bleed Jet
You want that bleeder blocked off. Given the age of the secondary vacuum diaphragm and its having hardened, increased vacuum is required to actuate the secondaries. This is what sealing that orifice at least intends to accomplish.
You can also modify the spring in the vac. diaphragm housing...
eldudo1981
posted December 08, 2011 07:50 PM
In any case I need to get another bleeder. Mine is now in multiple pieces. Got a part number or anywhere to find one?
0.018554925918579 seconds processing time
