Thread: Flange part number
posted November 12, 2010 12:11 PM |
Flange part number
Does anyone have a part number & brand for a new driveshaft flange? You know, the flange at the rear of the driveshaft that bolts to the pinion flange?
My driveshaft shop is having a hard time finding one with the right bolt pattern / dimensions / center hole size.
posted November 12, 2010 01:24 PM |
Flange
Brad, the same flange fits a courier and a B2000 all the way to year 1984. I know I used the REPU driveshaft in my B2000 conversion I did several years ago. Also the same center chunk is interchangeable thru all those years.
posted November 12, 2010 03:57 PM |
Thanks! Driveshaft shop said they don't have that flange new in aluminum that would use the larger u joints, series 7260 or 7290 u joints.
It is available for a smaller u joint. So now I'm stuck.
Dan and Andy, do you have any part numbers or details on your driveshafts? Part numbers?
posted November 12, 2010 04:00 PM |
I don't have the details... I just brought the truck down to the local driveline shop, 3 days later it was done. I'll try to look under the truck and see if there are numbers.
I'm The Admin, thats why!
posted November 13, 2010 03:19 AM |
driveshaft flange (yoke)
Mazda number is 0578 25 121
I have a used driveshaft and I think I also have some new flanges. Will check
Bruce Toski
954 583-4191
posted November 15, 2010 07:36 AM |
Driveshaft flange
Have one new Courier flange. $90 plus shipping
posted November 15, 2010 11:08 AM |
Thanks Bruce I will keep that in mind.
I'm looking for an all aluminum new 1 piece driveshaft.
posted November 17, 2010 10:41 AM |
Edited By: Brad on 17 Nov 2010 10:53
No one has the part number so no aluminum for me.
Shop is going to rebuild my stock driveshaft, new greasable u joints, new complete center bearing assembly, new yoke and rebalance if it's straight enough to be reused.
The longer the driveshaft, the more need for a 2 piece anyways. Smoother operation.
posted November 17, 2010 05:23 PM |
No one has the part number ?
thought I posted it
posted November 17, 2010 06:12 PM |
Edited By: Brad on 17 Nov 2010 18:13
for the aluminum rear flange i needed. it's the 3rd post of this thread.
crit
Finally REPUing
posted December 06, 2010 01:43 PM |
That flange PN is still available from the dealer. Go get it while you can.
84 GSL-SE
