Thread: Supercharging
RX8Guy
posted September 14, 2010 02:21 PM |
Supercharging
Bolting a Camden supercharger on my 74 today. Hate to change it from original, but just gotta do something. Gettin bored.
If it aint broke, dont fix it!
Klaus42
posted September 14, 2010 03:06 PM |
Edited By: Klaus42 on 14 Sep 2010 15:07
I take it you were already running a header and electronic ignition dizzy?
If not... you need to.
mattraver
posted September 14, 2010 10:52 PM |
hope you are using turbo rotors and ceramic apex seals,or that motor is as good as gone.i tune a lot of cars at my friends dyno shop and if the motor isnt built right they do come apart .every 2 lb of boost =1 point on compression .a header doesent make much of a difference and neather does msd boxes and such.camden roots style super chargers also make a lot of heat because of the vane design and there is no intercooler .hope this can help
RX8Guy
posted September 15, 2010 11:28 AM |
Edited By: RX8Guy on 15 Sep 2010 11:30
Yes on the headers
My brother and I ran superchargers on rotor motors as far back as 1976, and only ran over the counter Mazda parts (were a Mazda dealer) and havent had any issues with motors breaking. We only run about 12 lbs. of boost. I see the astronomical boost #'s that some of you younger rotor heads run and I'm astonished anything stays together. Fuel infected and using a computer. I'm still an old carburetor guy. We were supercharging and turbocharging with home made crap before rotary racing was cool. Now I'm paying somebody else to install my blower. Thats what starts happening when your almost 60.
posted September 15, 2010 01:44 PM |
Hey Bob, almost 60 and still a rotor head. That is to cool! Did you ever get the valance on the truck? Is it true that 2011 is the last year for RX8's?
1974 Mazda Repu
1986 Yamaha RZ 500
1988 Yamaha YSR 50
1991 Suzuki RGV 250
1992 Yamaha TZR 250 SP
1996 Aprilia RS 250
2003 Ford F-450 6.0 Diesel
2004 Mazda RX8
2006 Yamaha Banshee
2014 18' Eclipse Toy Hauler
posted September 16, 2010 09:51 AM |
RX8Guy, what are the specs on the Camden? Is it 5" or 7"? what size pulley?
fliboyz6
great
posted September 16, 2010 06:18 PM |
talked to the atkins guy and on his 9.91sec drag car he runs a 7inch blower and has never blown his motor
RX8Guy
posted September 17, 2010 08:59 AM |
7" blower, whatever pulleys that came in the kit. If the boost is too high, Ill change pulleys. It dnt just "bolton" a 74 model...havin' to make some adjustments, brackets, machine out the pulleys.....normal shit. hope to git it going today.
RX8Guy
posted September 30, 2010 08:55 AM |
Got it on and it runs great. unfortunately the blower vibrates more than the engine, so I've taken a perfectly smooth drive train and added a vibration. Not bad, but is there. Sure put a kick it butt though.
posted October 01, 2010 07:44 PM |
Yeah, my 5" vibrates a little. The 7" is smooth. Glad you got it working!
Klaus42
posted October 03, 2010 09:22 AM |
Can a blower be "balanced and blueprinted"...?
RX8Guy
posted December 22, 2010 12:26 PM |
quote: Hey Bob, almost 60 and still a rotor head. That is to cool! Did you ever get the valance on the truck? Is it true that 2011 is the last year for RX8's?
Sorry for long over due answer. Yes, got the valance on way back. looks great and fit great. and 11 will be the last year for the RX8. were hoping for an RX with the 16G, but thats not looking promising either due to emissions.
spokanerxdude
Less cubes... More balls
posted December 23, 2010 04:43 AM |
Glad to see that there is more than one of us old guys out there. I'm 57 and still rotat'n.
509-998-9024
posted December 23, 2010 08:25 AM |
quote: and 11 will be the last year for the RX8. were hoping for an RX with the 16G, but thats not looking promising either due to emissions.
I don't know how MAZDA will overcome this since the motor is designed to burn a small amount of oil all the time and gets poor mileage by nature. Direct injection can help some with mileage but not with the oil metering pump.
I wish it was a matter of adding another catalytic converter.
RX8guy
posted December 23, 2010 09:04 AM |
I've sent in my 2 cents worth several times to MAZDA. If they would stop taking the oil out of the crank case, and instead have a separate reservoir with the right kind of lubricant in there, they wouldnt have a problem. Hell they could run castor oil. And a one gallon reservoir would last the average driver 8000 miles. If they changed oil every 5000 as they should the oil injection system shouldnt ever run out. If the owner is stupid enough to go further he deserves to burn up an engine. They could put a fail safe on there that if the injector tank got low the motor would only run 2000 rpm. But what do I know. I told them in 04 they had the oil too lean. it took them two years to agree with that one and fix it. Im just an old hick from Texas, what could I possible know......
Klaus42
posted December 28, 2010 09:56 AM |
Absolutely!
quote: I've sent in my 2 cents worth several times to MAZDA. If they would stop taking the oil out of the crank case, and instead have a separate reservoir with the right kind of lubricant in there, they wouldnt have a problem. Hell they could run castor oil. And a one gallon reservoir would last the average driver 8000 miles. If they changed oil every 5000 as they should the oil injection system shouldnt ever run out. If the owner is stupid enough to go further he deserves to burn up an engine. They could put a fail safe on there that if the injector tank got low the motor would only run 2000 rpm. But what do I know. I told them in 04 they had the oil too lean. it took them two years to agree with that one and fix it. Im just an old hick from Texas, what could I possible know......
Yep. (Not to mention any more radical/interesting possibilities.)
...corporate priorities...
