Thread: Got my first REPU this weekend, need electrical help.
ericryan
posted March 08, 2010 10:35 AM |
It runs great but the stock alternator was failing. I have an N350 alternator from a S5 N/A RX-7, I have everything installed but the wiring harness. The factory REPU harness has 3 wires going to the back of the alternator, the N350 only has input for 2 wires.
Few questions:
Which wires need to go where on the back of the alternator? And where should the 3rd wire go? Also, do I have to jumper the regulator connections or simply disconnect it?
Thanks guys.
posted March 08, 2010 12:59 PM |
In order to swap out the original REPU alternator for the S-5 you will nrrd to disconnect the vltage regulator and install a jumper. Not sure on which terminals, can let you know later.
Check out these links and they will help you on wiring to the series 5 alt.
I think all you need to do is wire reference voltage to the S terminal. The L terminal is for alt warning light.
Good luck.
http://www.rx7club.com/attachment.php?attachmentid=199213
http://www.rx7club.com/attachment.php?attachmentid=170065
EricRyan
posted March 08, 2010 05:27 PM |
Awesome, I'll finish tomorrow when I have daylight. Thanks!
EricRyan
posted March 19, 2010 11:45 PM |
Truck's fully legal and plated, enjoyed driving it today to and from work for the first time. N350 alternator is working nicely. Started welding up new floorboards today and progress is so-so. The sooner I finish them, the sooner I can begin painting.
Man...REPU's are awesome :)
