Index > Engine/Drivetrain > Thread: exhaust differences
travisk
posted October 03, 2009 03:00 PM
exhaust differences
just curious on the exhaust of my 75 there is 2 gaskets on the extra engine i got with the truck it has a single gasket like the rx4 gasket. my question is what is the small holes beside the exhaust ports? and what exhaust manifold do i need to use?
thanks in advance trying to swap engines out and this is the first issue i have ran in to.
travisk
posted October 04, 2009 10:00 PM
guess nobody can help with this question.
can someone atleast tell me what header most are running i know race beat quit making the repu header is there another one that will fit without modding it?
posted October 05, 2009 07:04 AM
You can still get a header for it. The single outlet is no longer available. The roadrace which is the dual outlet fits right on. I have one on my repu. Here is the link.
http://www.mazdatrix.com/getprice.asp?partnum=16003
travisk
posted October 05, 2009 07:39 AM
Edited By: travisk on 5 Oct 2009 07:44
hey thanks for the info i'll be ordering that as soon as i get my next paycheck.
now i just have to figure out the rest of the exhaust.
gborch
posted October 05, 2009 11:15 AM
The other hole you are looking at is probably for the smog equipment/ air control . . if we are talking about the same thing. Unless it is the two piece gasket that was on ealier model REPU for the exhaust.
You can get a block off plate for that.
http://www.mazdatrix.com/e7.htm
travisk
posted October 07, 2009 09:26 PM
so i know the roadrace header will fit all 74-78s and if it fits the truck why wouldn't the 74-78 2into1 header fit the trucks? might be a dumb question but kind of confusing.. also is the a 2 into 1 that anyone has used with little mods maybe to the collector area of the header? sorry for all the questions but really can't afford a header and to redo all of my exhaust at the moment so kinda would like to go with the 2 into 1 style.
posted October 08, 2009 07:32 AM
I see yout point but I don't have an answer. Best bet is to call Racing Beat or Mazdatrix.
1974 Mazda Repu
1986 Yamaha RZ 500
1988 Yamaha YSR 50
1991 Suzuki RGV 250
1992 Yamaha TZR 250 SP
1996 Aprilia RS 250
2003 Ford F-450 6.0 Diesel
2004 Mazda RX8
2006 Yamaha Banshee
2014 18' Eclipse Toy Hauler
gborch
posted October 08, 2009 10:25 AM
The 2 into 1/ collected header is a little longer than the road race header. The welding flange is extended out longer. Without adjustment you will hit and have conflict with the transmission bracket/mount.
TimPA136
posted January 18, 2010 09:20 PM
Raceing Beat header
Travisk,
Interested if you got your exhaust figured out.
Tim
mattraver
posted January 19, 2010 07:04 PM
i did a racing beat build your own road race header kit and saved some $.my truck has dual 2" exhaust , my preres is a 2 in 2 out magna flow i cut both sides open and packed it with stainless steel wool (course 1 lb from mcmastercarr). Some guys buy lava rocks and fill the hollow muffler with that. muffler in the back is dual 2"to single 2 1/2" magna flow . works like a champ . my single 2 1/2"exhaust was not as good . You can buy manderal bends from jegs along with strait pieces of pipe .had about 400.00 in parts .was a pretty budget build but the results were great.dont worry about the length if its stock or street port ,racing beat said it really didnt matter.
TimPA136
posted January 26, 2010 10:03 PM
mattraver
quote,
Having just done a REPU single exhaust, I'm impressed with the improvised baffling. I have some greasy BBQ lava rocks outside if I had only known.
Hope you can make our next local meet mattraver.
Tim
travisk
posted January 28, 2010 12:25 AM
yea i got the RB header for the rx4 the collector hit the trans cross member so i made a new cross member that was shorter height wise.
TimPA136
posted January 28, 2010 08:28 PM
Travisk,
Good to hear you got that to work by modifing the trans mount and cross member.
TimPA136
posted February 13, 2010 04:10 PM
Edited By: TimPA136 on 13 Feb 2010 16:11
local meet
Travisk,
Hope you are able to attend our next local meet.
Tim
0.035805940628052 seconds processing time
