Index > Engine/Drivetrain > Thread: Engine rebuild/replacement options.
ScottyG
posted September 23, 2002 06:09 PM
Here's the deal:
I have a decent '74 Repu that is in need of an engine overhaul (lots of smoke).
I would love to retain the original 4-port 13B, so here's the first few questions:
-Should I attempt to rebuild what I have?
-Find a used one (but where?)?.
-Buy a rebuilt version (from whom?)?
Or would it be more practical to put a 6-port in it?
-What's generally involved in a swap?
-Retain the carb or retrofit it for F.I.?
-What's the difference in hp/torque?
I realize this is a big list of questions, so any or all questions answered will be appreciated.
Scott.
Rotor
certifiable rotorhead
posted September 24, 2002 08:34 PM
Here's the deal:
Sure, why not! If you wanna keep it original, rebuild what ya got. You can still get the parts, and it's not that hard to do if you are so inclined!
Hard to find them these days.
Go that route, I'd go with a Mazda rebuild. Although some of the aftermarket rotary builders don't do too bad.
6 port is a fairly straight swap. All you need is an adapter for the 4 port manifold to 6 port engine. Or you can use the D'ellorto/weber conversion.
See above. FI would be neat, but requires a good bit of work.
My guess would be fairly little. FI big advantage is driveability and fuel economy.
Scott.
ROTOR
0.019292831420898 seconds processing time
