Thread: tranny
lil-blue
posted February 16, 2009 01:15 PM |
tranny
will a first gen rx7 tanny handle a turbo 13b power not plaing on running slicks or any thing too sticky just dont wanna do the custom drive shaft any body running first gen tranny
spokanerxdude
Less cubes... More balls
posted February 17, 2009 07:53 AM |
1st gen tranny
From what I've read, a first gen tranny is good to about 250HP after that things start coming apart. Keep in mind I'm no expert and hopfully someone with more knowlage than I will chime in. No I Can't Spell. ;)
509-998-9024
posted February 17, 2009 03:49 PM |
Do not drag race. It will destroy the tranny.
Gentle application of throttle is your friend.
Less boost = longer tranny life.
Turbo ][ tranny is a better bet. If you can find one that's not worn out.
posted February 18, 2009 06:48 AM |
i had a used 1 gen tranny in my truck. I was used with over 100K and lasted less than 6 months. Upgrading to T-2. My motor is a tired, weak, ported 13-b with stock carb. BTY, I have the Torsen posi in the rear end so that will put more stress on the tranny. Good luck.
lil-blue
posted February 18, 2009 11:23 AM |
torsen posi
hows the posi working out and how hard is it to get it to work
posted February 18, 2009 06:29 PM |
The Torsen is AWESOME. No more single wheel burnouts and not my truck can do DONUTS. Put a nice circle in front of my house. My wife was ticked...thank God elderly neighbors are deaf. Buy Torsen kit from fuzzy-eyed, 77 repu ring gear spacer and bolt bolt size is different from 74-75. If you can use dial indicater for setting ring/pinion lash and axel thrust it's not bad. If you rip into pinion gear bearing it'll be a headache. Definitly upgrade to T-2 tranny.
