Thread: 85 13B oil pan question
mazdaorbust
posted June 21, 2008 01:03 PM |
Hello,
I am planning on dropping in a 13B out of a 85 rx7 into my 75 repu. The last repu I had I dropped in a 13b out of a 86 rx7 and had to change the oil pan. Does anyone know if the oil pan from a 85 13B will work without modification or will I have to locate a older oil pan?
Any help would be appreciated.
posted June 21, 2008 10:11 PM |
you need a stock repu oil pan
need a repu oil pan. 1st gen pans don't fit - steering center link is in the way. IF you can't find a repu oil pan, the moroso oil pan for 13b will fit. Don't get the moroso one that has cross braces, just the one they list for older mazdas or for putting a 13b into a old corolla or something like that. summitracing.com is where i got mine.
mazdaorbust
posted June 22, 2008 10:46 AM |
Hey Brad,
Thanks for the info. My problem is that I have been building my truck on a tight budget bacause of other responsibilitys. Do you know anyone that would have a stock repu oil pan that would be willing to part with it? Most of the parts I have picked up have been bought used from other members. What do they say "one man's garbage is another man's treasure". A creed I follow until I get back on my feet.Any help would be appreciated.
Thanks
mazdarx605
posted June 22, 2008 05:51 PM |
Hey Hector,
Contact Chiqui who is close by in CT. He has a parts truck that may have an oil pan,but I am not sure. He posted up the truck here last week of so,and said he was putting it on Ebay. I wanted parts,and/or the whole truck,but it seems he just wants to part it. I never heard back from him on the price for the whole truck.
posted June 23, 2008 11:50 AM |
I'm not sure what Brad is smoking. Any '84-'85 GSL-SE pan will fit your REPU. I know. I've done it.
posted June 25, 2008 08:22 AM |
well
Thats what I've heard in the past.
tom93r1
posted July 02, 2008 01:12 AM |
quote: I'm not sure what Brad is smoking. Any '84-'85 GSL-SE pan will fit your REPU. I know. I've done it.
Thats what I was thinking, in fact I am pretty sure thats what I have on my REPU.
FernandoLuna
posted July 03, 2008 12:38 PM |
I`m preety sure the GSLSE pan fits the REPU. What you cant do is the reverse. The old pan interfers with the GSLSE direction bar.
Good Luck
Fernando Luna
Rotary Shop
Spokanerxdude
Less cubes... More balls
posted September 01, 2008 11:12 AM |
crit
Finally REPUing
posted November 24, 2009 08:46 AM |
posted November 24, 2009 09:48 AM |
Be sure to loctite the studs to the bottom of the engine. Pineapple didn't and several were not even hand tight when I removed them for a rebuild recently. Caused the pan to leak oil of course.
Blue locite should do the trick, only put it on the end that threads into the engine. Not the nut end of the stud.
Nice pan, has two little 'trap doors' to keep oil in the front of the pan during acceleration.
mattraver
posted November 24, 2009 10:41 PM |
the gslse pan fits (5 qt)but the repu pan holds +1 qt .no need to use sandwitch plates that was only an old recall , and ford diesel sealent works the best , they use that sealent to plug all the 6 liter diesel leaks .also atkins rotary sells old repu pans for about 100.00 1 253 848 7776.
Klaus45
On two wheels
posted November 25, 2009 09:01 AM |
I'll beat that price
quote: the gslse pan fits (5 qt)but the repu pan holds +1 qt .no need to use sandwitch plates that was only an old recall , and ford diesel sealent works the best , they use that sealent to plug all the 6 liter diesel leaks .also atkins rotary sells old repu pans for about 100.00 1 253 848 7776.
...for an oldskool pan.
mattraver
posted November 30, 2009 09:56 PM |
then beat that price pan master
Klaus45
On two wheels
posted December 02, 2009 12:13 AM |
Oil Pan
quote: then beat that price pan master
Email sent.
mattraver
posted December 02, 2009 12:40 AM |
dont have a pan for sale , but if you have a battery latch for sale call 925 383 9899
Klaus45
On two wheels
posted December 02, 2009 08:01 PM |
quote: dont have a pan for sale , but if you have a battery latch for sale call 925 383 9899
Whaddaya mean, "don't have a pan for sale" -- I thought you were looking to purchase one? I have one.
midnightriders
posted April 20, 2010 09:29 PM |
the 12a that i have in mine fit stock pan and everything... and yes i know, workin on finding a stock 4 port for it, this is a temporary
'74 white RePu
rb26 awd 240sx (yea i know)
blwfly
posted April 22, 2010 07:05 AM |
i used a gslse pan on my s4 t2 swap?? no problems
74 repu getting a s4 t2
