Thread: RB Holley carb
tpfister88
posted March 13, 2008 03:08 PM |
RB Holley carb
My secondaries are not working. They sprinkle very little but I can kick them in manually. any suggestions?
74 Green/Primer REPU
repu510
posted March 13, 2008 09:31 PM |
was the carb running good before?
otherwise, there could be a number of things that could affect fuel delivery. dirty fuel filter, float level, clogged jet, etc.
tpfister88
posted March 14, 2008 07:21 AM |
It was working good but has sat for about four years. I have only had it running again for about a month now and it runs fantastic other than secondaries. I tried a paper clip on it to check and see if they were opening under a load and they are not. Nothing is binding because i can open them manually.
thanks
posted March 14, 2008 08:55 AM |
Vacuum secondaries?
Trouble could range from a vacuum leak, to (a) dirty, clogged circuit(s); vacuum hoses, caps, and diaphragms have a bad habit of aging/cracking/deteriorating/hardening over time... and fuel residue becomes varnish, and even a little bit of dirt, (let alone a spider, or some such) can clog a passage...
repu510
posted March 14, 2008 12:03 PM |
if its been sitting for years
you should seriously consider a carb rebuild then. all kinds of build up occurs over the years and it doesn't take much to clog up a fuel passage, jet, or something in the carb. they are very sensitive to impurities. i've found this out the hard way over the last year. luckily, the bus runs close to work for me! haha...
tpfister88
posted March 14, 2008 06:38 PM |
Ya'll are right, i was just trying to talk myself out of pulling it off. The carb has less than 500mi on it but has been on the truck for about nine years. I've run a couple tanks thru it hoping it might straiten itself out with some use but no luck so far. I guess I will pull the carb off tomorrow.
tpfister88
posted March 16, 2008 08:40 PM |
Made some adjustments and secondaries are opening a little...thinking maybe a lighter spring.
tpfister88
posted March 16, 2008 08:45 PM |
Just a thought but having new exhaust installed would not cause any decrease in vacuum would it?
posted March 17, 2008 08:33 AM |
Not unless...
...you deleted any stock bits that you forgot to plug, or something deteriorated, or got knocked loose in the process...(?)
tpfister88
posted March 17, 2008 10:10 AM |
No sir just from the header back.
