Thread: more weber carb questions!
repu510
posted February 04, 2008 06:24 PM |
Curious if anyone has run a Weber 48 DCOE sidedraft carb on their REPU? If so, which jet settings did you use? Is it wrong to assume similar base jet settings similar to a Dellorto 48?
posted February 05, 2008 08:46 AM |
totally different jetting then dellorto. the dell uses a very lean e-tube which necessitates larger main fuel jets.
search rx7club.com for 48 dcoe jetting.
repu510
posted February 07, 2008 10:44 AM |
there were a few threads w/ 45s w/ 12As. sparse info on running a weber 48 dcoe w/ a 13B. thanks for the lead. i was able to find some stock jet settings on the weber site for how the factory ships the carbs. there are settings for a SP 13B from RB. i suppose i could use that as a base line and tune down to a stock port.
tom93r1
posted February 07, 2008 01:24 PM |
Edited By: tom93r1 on 7 Feb 2008 13:29
I have a Weber 48 DCO on my REPU. I had been running it on a stock ported 6-port motor but just replaced that motor with a heavily ported 4-port turboII motor.
I dont remember exact jetting, but on the 6-port I had I believe a 55 idle jet, a 210 main, and maybe 180 air corrector? It was never exactly perfect and my timing was off because of no timing marks so I am sure the jetting wasnt where it should have been either. Not to mention I just disassembled the DCO and found a few gummed up passages which I am sure made the jetting that much more wrong.
Now I have a wide band to install, have timing marks on the pulley, and hope to have it jetted fairly soon. I just need to work out an exhaust so I dont scare the neighbors when driving around the block.
Also, if you have a hard time finding jets locally I have bought from the guys at racetep.com
http://racetep.com/weberX.html#jets
When buying locally look at the VW shops, dont worry about the looks you get when asking for something like a 210 main. They just dont understand because to them a 160 is huge.
repu510
posted February 11, 2008 12:06 AM |
more good info! thanks for the leads. if and when i get my carb hooked up, i'll post my settings as well.
