Index > Engine/Drivetrain > Thread: new to the forum
UNDISPUTEDFB
posted December 18, 2007 10:50 AM
new to the forum
i dont have a repu, but i do have a 75 rx4 wagon so close enough, anyone have a write up of removing the smog equipment from the motor and what and where certain hoses need to be connected? any help is greatly appreciated
whats really good
posted December 18, 2007 11:42 AM
Greetings!
I used to have rx-4's, m'self... no different underhood from the REPU, really.
You'll want the Racing Beat header suitable for your application, as well as the Air Control Valve block-off plate, and perhaps a pair of blocking nozzles, etc., etc.
Basically, everything you end up removing needs capped off or securely plugged.
If you search around on other, older threads here on the forum, there might even be some pictures that will prove helpful.
UNDISPUTEDFB
posted December 18, 2007 11:45 AM
Edited By: UNDISPUTEDFB on 18 Dec 2007 11:45
nice, thanks for the info, also, that damn little check valve that goes under the carb, any special part number or can any valve be used?
whats really good
0.020795106887817 seconds processing time
