Index > Engine/Drivetrain > Thread: rx7 s4 N/A manfold fit under the hood?
rotaryguyseth
posted January 23, 2007 07:52 PM
does any one know if a rx7 s4 N/A manfold fit under the hood
trochoid
posted January 27, 2007 03:09 PM
Well, since the S4 TII engines with the top mount intercooler fit under the hood of a REPU, I see no reason why the NA version wouldn't. You will need the front cover and oil pan off of the REPU to mount the engine.
troyjmueller
posted February 20, 2007 06:35 PM
engine mounting points
maybe not oil pan, unless there is a different sump?
Front cover from any 12A (80's carb rx-7), or 13b gslse will work for front-mounts as well. Differences is the number of oil lines, 4 for the na 13b fi, 2 for the carbureted models.
0.018519878387451 seconds processing time
