Index > Engine/Drivetrain > Thread: RX7poweredREPU?
slelack
posted June 18, 2002 12:49 PM
RX7poweredREPU?
In my 77 REPU I puled out the old stock engine and dropped in a 13B from an 86 RX7. I gave it a street port and put a 36mm sidedraft webber carburator on it. I also put a racing clutch in it and still run the truck transmision. It all bolts together the same and didnt require any force getting it together.
posted June 26, 2002 01:18 PM
Are you sure it is a 36mm sidedraft you put on? That sounds really small. I did the same thing as you but my motor isn't ported and I have a 48mm sidedraft carb. I think the hardest part of the job was finding an oil pan.
Did you figure out a way to run your OMP or do you just use an oil pre-mix? I went the pre-mix route but would love to hook up the OMP again and not have to worry about oil at the gas station.
Rotor
certifiable rotorhead
posted August 26, 2002 10:46 AM
Swap the front cover and use the stock metering pump.
ROTOR
posted August 26, 2002 10:53 AM
1st gen OMP
I'm using the stock 1st gen OMP, it only has 2 lines coming out of it, so I have to T it into the 2 oil injectors per line (4 total)
I have new pics I just have to upload... My T2 REPU is almost ready to get smogged... just need the last bit of wiring harness left!
posted August 26, 2002 11:26 AM
So by running a first gen OMP you wouldn't need to use premix when using the Haltech?
0.023236989974976 seconds processing time
