Index > Engine/Drivetrain > Thread: Radiator
Thread: Radiator
posted June 16, 2006 10:09 AM
Radiator
Where can I get a new radiator?
posted June 16, 2006 01:27 PM
i had mine recored at a radiatorshop
180 out the door.
NEW mazda ones are NLA.
try radiators.com or the other usuals like carparts.com, kragen.com.
xp882
posted June 16, 2006 03:28 PM
i had mine record also couldnt find one.. made it into a tall 3core which is the same as a 4 core pretty much
posted June 16, 2006 06:06 PM
I was considereing a recore. The top head on the radiator was damaged and had a frankenstein job done on it before I got the truck. If I had to I guess a recore would work as long as I can braze up the top head.
Anyone have a non-repu/after market performance radiator in their truck?
posted June 17, 2006 12:00 PM
aftermarket radiator
check out summitracing.com they sell many differnt sizes and thickness radiators.
i use a HOWE brand aluminum radiator on my rx7. and oil cooler in front of radiator. HOWE lists it for a chevy but the dimensions all worked out. BUT the upper hose inlet is on the drivers side instead of passengers side. so i just used a generic long hose with a spring inside it from kragen.
good hunting.
0.018848896026611 seconds processing time
