Index > Engine/Drivetrain > Thread: any one drop there gas tank?
xp882
posted June 15, 2006 04:52 PM
is it alot of work? looks like four bolts holding it in.. im not getting fuel from the tank for some reason? but i blow in the line and here it bubble does the return line a must to be hooked up? thanks
posted June 15, 2006 09:47 PM
4 bolts and there is a little bracket i had to bend out of the way. disconnect the fuel return fuel filler tube and the smaller hose from fuel filler neck, and the main fuel line first. the fuel return line is a pain to get to; lower the tank a few inches then disconnect it.
check the fuel pump and fuel filters.
disconnect fuel line from carb. blow compressed air from just after the fuel pump, see if it pushes any crud out of the line.
dubbayoc
posted July 19, 2006 01:48 PM
ya man...hook that return line up.
0.73881196975708 seconds processing time
