Index > Engine/Drivetrain > Thread: electronic dist?
xp882
posted June 06, 2006 09:48 PM
electronic dist?
hello my swap is almost complete all i need to do i hook up the dist to the coils anyone know of an easy using what i have 2coils 1elec dist.. guide with pictures? thanks so much
xp882
posted June 07, 2006 06:00 PM
can i just hook the coils up directly? thanks
xp882
posted June 08, 2006 07:55 PM
is the best thing to do get a harness from an rx7?
bwaits
posted June 10, 2006 06:06 AM
Go to www.rx7club.com and search for "direct fire" in the first gen section. You will find many threads on how to wire up what you have.
-billy
ReSpeed Online Catalog
posted June 10, 2006 10:30 AM
Wasn't there a thread around here...
...a while back detailing the install? (Or was that for a different/earlier version?)
Which year e-dizzy, which year's coils?
xp882
posted June 11, 2006 05:58 PM
i dont want direct fire i just wanna get it started.. its a 81-85 dizzy and malory coils..
bwaits
posted June 12, 2006 12:52 PM
I mis-read your post that you had 2nd gen coils - you have two coils. In that case easy install.
The electric dist. has two ignitors. Each ignitor has two terminals. If you visualize the terminals they make a "T".
The ignitor toward the front of the car is the leading. The other is trailing.
You need:
12V switched power to the positive of both coils.
You need a wire running from the top of the "T" of each ignitor to the positive of each coil.
You need a wire running from the other terminal of each ignitor to the negative of each coil.
Done.
-billy
xp882
posted June 12, 2006 09:33 PM
i have old school coils and 84 elec dizzy. i got the harness from the rx7 hooked it up and ran the 12v to the + on both coils now the + and - look like they are getting power is that right?
0.025647878646851 seconds processing time
