Thread: cosmo 13b tt in repu ?
rxkevin
posted November 12, 2005 09:35 PM |
I am seriously thinking about doing a cosmo twin turbo swap with the auto and stock ecu and I was just wondering if any one else has done this project before?
1984 RX-7 with 1993 13b rew drive train, t-66, power fc.
1974 REPU dellorto, racing beat header, 3 spd auto
wankelbro
posted May 23, 2006 07:14 AM |
Twins for REPU
I am using a Turbo II 5 speed trany and microtech . Is not quite done but I can not wait
posted May 23, 2006 02:09 PM |
I think you will have a hard time fitting the twins, there will not be much room for a downpipe without cutting into the shock tower.
wankelbro
posted May 23, 2006 02:24 PM |
Twins
It fit perfect without cutting anything . I am using the downpipe form the twins . I really do not want to cut anything . Thank You
Norman
posted May 23, 2006 04:29 PM |
Thats cool, I may have to think up something to do with my spare set of twins laying around then.
wankelbro
posted May 23, 2006 05:27 PM |
Twins
give me a couple of months I will be happy to email you Pics ..
RotaryRob
posted June 06, 2006 11:07 AM |
Twins?
Hey Guys,
Just curious that you keep referring to your "twin" turbo'd engines. Are these Mazda units? Mazda never made any "twin" turbos that I know of. Please update me. All the turbo'd engines I know of from Mazda, such as the FD series Rx7, had DUAL turbochargers. One was small and spooled up quickly, while the other was bigger and provided boost at the higher revs. There were two of them, but they definitely weren't twins! Even the single turbocharger 'Turbo II' engine used that concept with a dual scroll compressor vane with different pitches and exhaust manifold valving that shifted the exhaust gases from the more accute angle to the lesser as the revs increased. Is there really a 'twin' unit from Japan or something that I don't know about?
'77 RPU
'75 RPU (V-6)
'76 Courier
Rotary Sprite (3 - 2 project)
'85 IT 7
EP '85 Rx7 (in progress)
'85 GSLSE (4)
C6 Corvette Roadster
tom93r1
posted June 06, 2006 11:19 AM |
The turbos in the 3rd generation (FD) rx7 and cosmo cars are indeed "twin turbos". They are identical size to each other but they operate in a sequential manner by using a very complex vaccuum hose and solenoid operated control system. I guess you could be more technically correct if you called it a twin sequentially turbocharged system.
xp882
posted June 06, 2006 09:49 PM |
how you guys runing your front mount intercoolers? cutting holes?
wankelbro
posted June 07, 2006 07:27 AM |
Intercooler
I am running water to air intercooler .It makes it easier to install .
posted June 07, 2006 10:44 AM |
Cut the fenders
It really hurt to do, but I cut the front inner fender...
I figured if some future owner ever wanted to go back to stock (?!) they could weld the holes back up.
It was better than cutting the hood... and less weight than using an air to water IC.
I'm The Admin, thats why!
xp882
posted June 07, 2006 08:04 PM |
ouch... have picture of air water installed? i need to find somewhere to do the piping for my turbo
