Thread: Electronic ignition conversion
mwpayne
posted April 30, 2005 12:13 PM |
Are there step-by-step instructions for this anywhere? I'd like to get the ol' REPU at least up to the 80' standards!
Thanks
posted May 01, 2005 11:41 AM |
There are a number of other threads here...
...discussing various aspects of electronic ignition; you might wish to research these older threads...
It's a pretty simple swap, get the first-gen dizzy with the ignitors right on it --not the 'remote-mount' version, which was prone to cross-triggering--; next you'll need to either re-locate your alternator bracket one bolt over, or slightly modify it; the e-dizzy drops right in, just like your points one... best to swap the coils, as well...
I do seem to recall pics posted here on an older thread showing the wiring...
Then you can also run the 'newer' BUR-series plugs, if you wish.
mwpayne
posted May 01, 2005 01:17 PM |
Excellent,thanks very much!
posted May 02, 2005 01:17 PM |
Run a search on my user name and DLIDFIS.
