Index > Engine/Drivetrain > Thread: turbo
Thread: turbo
98Jones
posted December 03, 2004 07:22 PM
turbo
Does anyone know how difficult it would be to put a turbo on a REPU? I am looking at buying one for a project and wanted to know if it would be easy to turbo it. If it would take work, what would it require?
posted December 05, 2004 02:14 PM
All the obvious stuff.
You'd need a motor set up to handle it --like the turbo II seven's-- and all the relevant bits. Of course it'd take work... Likely more so if you're not simply swapping in a complete, running setup.
Of course, you can always try to slap something together, and run it until it pops...
Steven
posted December 07, 2004 07:21 AM
All you need is the engine, harness, ecu, fuel system, turbos, exhaust to match. Not that hard to be honest.
I wouldn't try boosting the stock 13b. You are better off starting with a fresh motor.
74 repu
Rotaryrocket
posted January 22, 2005 05:03 PM
Its not a problem at all to do the turbo, you'd need to get a standalone system like from Microtech. Otherwise you would have to do a blow thru system (using the carbureuter).
posted January 31, 2005 03:12 PM
boost
The 4 port 13b from the REPUs has compression ratio of 9:2:1. Compare that to a T2's compression of 9:0:1 and that seems to be as close as it gets for the NA motors Mazda made.
0.0205237865448 seconds processing time
