Index > Engine/Drivetrain > Thread: J109 ignitors
gdw3138
posted November 30, 2004 04:34 PM
J109 ignitors
I blieve that I lost an ignitor today. The tach stopped working and the pickup would die at idle. It started easily and seemed to run alright. So I am guessing that I lost the trailing J109 ignitor. I am using an electronic distributor and the leading plugs are running off of twin coils with an MSD unit. I need to know what year(s) use the J109 ignitors. I guessed '81 and '85 but Schucks listed the same ignition module ($145). If I can't find a reasonably price new one, I'll look for used. Any idea of a good wrecking yard? (I'm SE of Seattle) Thanks.
lockwood7
posted November 30, 2004 04:44 PM
I have a new one for the 81-85 Rx-7 for $75 (Wells). It is larger than the original, but works excellent.
John
www.genuinemazdapartsandmore.com
posted December 01, 2004 12:00 PM
Have you seen my DLIDFIS article? http://www.geocities.com/cd23c/dlidfis.html
gdw3138
posted December 01, 2004 01:57 PM
I've read your article. Thanks. Now I'll need to look for three J109s since both of mine are dead. I already have my igniters located on a aluminum plate and the three coils.
posted December 01, 2004 05:25 PM
You could try GM HEI ignitors. They can be purchased cheaply at Autozone.
posted December 02, 2004 06:02 PM
I used to live in Kent, WA.
Ther are a bunch of auto wrecking yard in Kent. I think one of them is called Green River auto Wrecking. They are pick a part. I would reccomend trying to buy the entire distributer. Most of the yars I've been to up there sell them cheap and don't bother to notice the 2 ignitors attached. God luck, Sparky
0.018797159194946 seconds processing time
