Thread: Fuel Pump replacements?
rdahm
www.TurboRX7.com
posted November 25, 2004 03:59 PM |
My fuel pump is going. it seizes from the metal on metal rubbing because the lubricated surface is worn away. is there a direct replacement or does someone have a new one for sale? I have attempted to repair it but it still seizes.
'93 Touring RX-7
'88 GXL RX-7
posted November 25, 2004 11:23 PM |
Facet pump.
Search ebaymotors, or elsewhere...
posted November 26, 2004 03:16 AM |
electric fuel pumps
I have never been realy happy with the longevity of these pumps. That said, it appears the original number is NLA. You might try 8871 13 400 B. This RX-7 pump is still supposed to be a good number in the Mazda system and will "probably" be the same little 2 hole mount bugger.
You should aalso be able to locate an aftermarket pump. Like Klaus said, the name I generally have seen is "FACET", but they don't seem to last as long as the factory ones. If you can't find something for some reason give me a call.
Bruce Toski
954 583-4191
lockwood7
posted November 26, 2004 05:48 AM |
I have a new one from a 79-85 Rx-7 made by Federal Mogal. $60 and $6 for shipping. I also have posted several REPU parts to Ebay at www.genuinemazdapartsandmore.com
Let me know - you can also buy direct. The parts are new and the prices are good.
John
posted November 26, 2004 12:44 PM |
Edited By: Jeff20B on 26 Nov 2004 12:46
Facet pumps are so weak! I have three of them. Well, four, but one would bind internally. I don't like these pumps. They either run low in the float bowls at idle due to not enough pressure for the Hitachi, or cannot provide enough volume for normal driving up a hill/accelerating, or both. I'm in the process of replacing them with more capable pumps.
I may connect two of these Facets in parallel for more volume.
posted November 26, 2004 01:08 PM |
Edited By: klaus42 on 26 Nov 2004 13:09
Absolutely
...good points! Just so long as sufficient, consistent voltage is getting thru our ancient wiring to the pump(s) to begin with...
