Index > Engine/Drivetrain > Thread: WHO has pictures of oil cooler mounting
posted June 07, 2004 11:14 AM
I need some pictures of how the oil cooler mounts to radiator.
My 74 came with a 12a oil cooler and Rx4 oil cooler brackets. The 12a mounting ear on pass side was bent outward to fit the bracket.
I now have a Rx4/REPU oil cooler but the mounting ears are two inches shorter than my 12a cooler. Was there some sort of L shaped oil cooler bracket or something? The Rx4 brackets I have are straight. Flat. No bends. 2" too short.
posted June 07, 2004 05:57 PM
Oil Cooler Brackets
Hello Brad,
I don't have any pictures but if you come up empty handed I can mail you a drawing for them.
Manteca Mazda Asylum
posted June 08, 2004 08:03 AM
Edited By: nwaco on 8 Jun 2004 08:03
I'll give it a try...
Here is the Drivers side. Pass is just the same, except opposite.
posted June 08, 2004 09:56 AM
I need at least one new one. The rubber things are no longer bonded to the metal.
posted June 08, 2004 10:35 AM
Not to mention
...what happens to that foam and glue over time...
posted June 08, 2004 11:07 AM
thanks a million klaus
that's exactly what i needed.
repu oil cooler tabs are bent at 90* whereas the rx4 one i have does not have a bend. just straight up tab.
i'll need to fab some brackets to make rx4 cooler work.
jeff i found some nice rubber oil cooler brackets. big fat round rubber stubbers. but they use 1/4 - 20 coarse threaded nuts so i had to tap my radiator mounting nuts. worked fine. threaded right in. and i got nylox nuts and grade 8 washers for it all too. i'll have pictures in a few weeks. they were about $6.50 each + nylox and washer.
once i have pictures i'll post where to get them.
posted June 08, 2004 11:16 AM
...uh, you might wanna thank
...Ken and the other guys. I mean, I really didn't have the pic for you in the nick of time, here...
(Haven't been on the 'net much, lately!)
posted June 09, 2004 10:29 AM
oops
!!!!!!!!!!!!!!!!THANKS NWACO!!!!!!!!!!!!!!!
0.023896932601929 seconds processing time
