Index > Engine/Drivetrain > Thread: Is the Rx7 Turbo ][ 5 speed an option?
posted April 28, 2004 01:04 PM
Anyone ever put a T2 5 speed tranny in REPU?
posted April 28, 2004 01:11 PM
Yep:
You'll need a new:
* Tranny Support Cross Member
* Drive Shaft
And the shifter sites far back, you'll either
A. Have to cut the floor :O
B. Move the move the shfter up
posted April 29, 2004 09:41 AM
Will a old ribcase or 79-80 rx7 tailhousing work with T][ trans? That would move the shifter up perfectly, if it's compatable.
EricHappyMeal
posted June 11, 2004 11:57 PM
so, how would you go about moving the shifter up so it goes through the origional hole?
        Click here to visit EricHappyMeal's homepage. Click here to send EricHappyMeal an AIM message.
EricHappyMeal
posted June 12, 2004 12:01 AM
oh, and where would i get the tranny brace and driveshaft?
posted June 13, 2004 10:43 AM
Fabricate
...'em, or have 'em made/modified to spec. ...?
EricHappyMeal
posted June 13, 2004 07:25 PM
heh
didnt know if there was one i could use or not, or if there was an easier way than all kinds of fabrication.
posted June 15, 2004 03:57 PM
I put a t2 tranny in my truck using the stock cross member and drive shaft.
1974 Mazda Repu
1986 Yamaha RZ 500
1988 Yamaha YSR 50
1991 Suzuki RGV 250
1992 Yamaha TZR 250 SP
1996 Aprilia RS 250
2003 Ford F-450 6.0 Diesel
2004 Mazda RX8
2006 Yamaha Banshee
2014 18' Eclipse Toy Hauler
posted June 15, 2004 04:54 PM
WHAT YEAR T2 trans?
posted June 15, 2004 07:54 PM
Hey Brad, it's an 88'. I bought it from mazdadragracing.com in Pomona, CA.
1974 Mazda Repu
1986 Yamaha RZ 500
1988 Yamaha YSR 50
1991 Suzuki RGV 250
1996 Aprilia RS 250
2004 Mazda RX8
2006 Yamaha Banshee
rotarydave
posted June 16, 2004 04:33 AM
at the very least you would have had to replace the flywheel on your engine and the yoke on the end of the driveshaft to use the T2 tranny.
I am very interested in this as well, i would like to hear from anyone who has done this modification and who modified the shifter location as well.
posted June 16, 2004 05:14 PM
Regarding my incomplete post.....
I did have to modify the drive shaft and cross member. I had a t2 yoke put on my repu shaft at a driveline shop, about $100.00. The cross member had to be lowered 1". New holes were drilled in trans rubber mount to line up with t2 bolt holes. And yes, (ouch!) the shifter hole does have to be opened up. Fortunately, my truck came with a 2nd gen. non turbo trans in it so the previous owner did all the cutting for the shifter. I think thats about it. Oh ya, had to change the fly wheel too.
1974 Mazda Repu
1986 Yamaha RZ 500
1988 Yamaha YSR 50
1991 Suzuki RGV 250
1996 Aprilia RS 250
2004 Mazda RX8
2006 Yamaha Banshee
rotarydave
posted June 17, 2004 10:59 AM
Has anyone done this mod without cutting the hole, i have been told it is possible to change the shifter location but don't know anyone who has actually done it, I know that you can't use the 79-80 Rx7 tailshaft housing trick like you can with the NA tranny because the output shaft is not the same size, any help would be appreciated.
posted June 17, 2004 01:59 PM
would a old ribcase 5 speed tailhousing work with T][ box?
rotarydave
posted June 17, 2004 02:30 PM
it may bolt up to the T2 tranny case but if memory serves me correct the output shaft is much larger in diameter than the NA trannies, hence the difference in the driveshaft yoke so i don't think i can use it.
of course everything is machineable.......
0.027253866195679 seconds processing time
