Index > Non REPU Rotary Trucks > Thread: who made my mtr????????
1repuwannabe
posted July 08, 2004 11:16 AM
79 ford courier with stock 2.0L the block is cast iron the head and valve cover is aluminum. the valve cover has OHC and firing order on it in raised letters. anyone help me??
Hello. My name is Dale and I'm a Rotaryaholic
klaus43
posted July 09, 2004 09:41 AM
Just a guess...:
Aluminum valve cover might be non-stock, or at least not original to your motor?
What can the oldest guy in your dealer's parts dept. tell you about it?
posted July 09, 2004 05:45 PM
May be an early Pinto unit. Made in Germany for the european sourced Capri, and a well respected racing engine. I don't quite remember if the Mazda/courier used that one. Replaced by the US "metric" 2.3 which for sure was used in the pickups.
If it is the German ford unit, many racing parts are out there. Ever hear of formula ford? Buddy of mine massaged a stock pinto to make enough HP to twist the body apart. Out dragged a GTO! I was with him when he did it.
formerly
rx2/3/4/cosmo,repu,94 rx7,
posted July 10, 2004 04:11 PM
Checked my Chiltons and it showed a picture of a timing chain on that motor. Pinto had a belt. Must be a Mazda unit. I don't think they used anyone else's till later.
formerly
posted September 29, 2004 10:05 AM
Mazda
Most likely its a 1800 Mazda unit. I've had couriers and B2000's and both had an aluminum valve cover with OHC and raised firing order. The early couriers had 1600, with later ones being 1800 then the B2000 came out with 2000s. I have some parts for a courier if you are in need of anything. Let me know what you need and I'll make you a great deal just to get it out of my way. Also have an 86 B2000 thats getting ready to go on the auction block if anyone is interested. CHEAP.. doesn't run, got a hole in the side of the block where it threw a rod.
Mazdafun
posted December 15, 2004 05:53 AM
What motor...
Hi.
I think it is a "MA" motor. It was a 2 litre that came with alot of Mazda vehicles.
Check the side of the block (cast iron), and see if it's got "MA" forget into it with raised letters.
Have a nice day.
wvoigt
posted April 10, 2005 07:48 PM
Check for old script m
I have a 2000 engine in my 1973 courier.The biggest differance between the 1800 and 2000 is 1 inch of block hieght. oh, and a bigger water pump. Value clover,oil pan, and intake manifold are all interchangeable.
1974 Repu
1973 Courier
1989 Car Dolly
wvoigt
posted April 10, 2005 07:50 PM
and
check under the exhaust manifold and you will find an old script M
1974 Repu
1973 Courier
1989 Car Dolly
0.023088932037354 seconds processing time
