Thread: maz bitz
klr626
posted February 09, 2004 07:26 PM |
maz bitz
i got a 1981 mazda 626
i have rx7 series II wheels and a 13 b twin dizzy motor
i want to supercharge it but some people tell me turbo is better
what should i do
posted February 10, 2004 09:20 AM |
off topic
How about posting on a board like rx7forum.com or nopistons.com ? This is a REPU (Rotary Engine Pick Up) board.
With that said, there are _quite_ a few more turbo setups and folks that know turbo-rotaries than supercharged rotaries out there. If you do want to go with the SC, try atkinsrotary.com.
I'm The Admin, thats why!
posted February 10, 2004 01:00 PM |
Edited By: klaus42 on 10 Feb 2004 13:02
"What should I do?"...
Get a REPU!
(When exactly did they come out with a 13B with twin dizzies? Did you build a 13B with early 12A parts? Why?)
posted February 10, 2004 01:15 PM |
Yeah really. I don't know what a twin dizzy 13B is. Even saying it to myself sounds wierd.
posted February 10, 2004 02:18 PM |
My guess:
It's a special race setup, so that you can dial-in timing beyond the norm... you know, for those motors that make all their power at 10-15,000 RPM...
posted February 11, 2004 12:51 AM |
Or better yet, it's so you can have two different advance curves; one specifically for leading, and the other for trailing. It allows different amounts of advance for each ignition system. It also can be load-dependent if vacuum advance is retained. Variable LT split is possible with this sort of a setup.
Would I even bother with such a setup? Nah.
posted February 11, 2004 11:45 AM |
Does make me wonder...
...what could be possible on the high-tech computer-controlled high-performance end of trick ignition setups...
How do they control the 4-rotor LeMans race engine?
posted February 11, 2004 11:52 AM |
They, in their infinite wisdom, sparked all three plugs at the same time per rotor face. If I were them, I would have found a way to spark the L plugs again 180º after the initial firing. I only say that because I found a way to do it on a 20B. I'm getting so close to test-firing it, I can taste it.
