Index > @ the Pickup Bed (General Topics) > Thread: how exactly does the control unit work?
Mazdarx605
posted August 04, 2003 06:11 PM
Hello all,
In my quest to get this new ride of mine in running order i have been trying and winning (mostly)the battle with electrical problems.I know the blinkers were working before but now aren't.The back-up lights were not working but i have figured them out.The horn isn't working and I have yet to figure this one out yet.There is a wire plugged into the horn button and a wire on the horn itself but if i manually close the contacts on what i believe is the horn relay in the control unit i don't get any sound.Also the wipers do work and i see the relays clicking open and closed on the CU.The blinkers did work but now aren't.The battery seems really weak even though my trickle charger says its charged.Could my lack of a horn and blinkers be a problem with a really weak battery?If I turn on the running lights they work but are sorta dim and if I turn on the head lamps they barely glow and the markers almost totally go out.
74 green REPU w/factory air
posted August 04, 2003 06:22 PM
....Could my lack of a horn and blinkers be a problem with a really weak battery?...quote]
possible
may not have enough power to operate the relays. Try hooking the charger up to the battery while it is in the vehicle with the ignition on. That may give you enough juice to operate the blinkers.
OR
go buy a new battery since it sounds like you definatley need one because your truck isn't going to start with that one.
posted August 04, 2003 06:23 PM
OR....best yet, just try a battery from a different vehicle
posted August 04, 2003 10:10 PM
And clean, clean, clean
all those connections! Sounds like your battery may have a dead cell... or just not be holding the charge, even as it appears to be taking... or: you could have a serious drain in your wiring. Another possibility: poor ground. You'd be amazed how something that simple can really screw everything up! Paint, rust, corrosion, dirt are all insulators...
posted August 06, 2003 08:48 AM
The location of the fuse block
on top of the 'shelf' under the hood also tends to exacerbate electrical issues...especially since many are missing the plastic cover... (may require periodic cleaning/maintenance...)
Mazdarx605
posted August 07, 2003 03:31 PM
Update
I bought a new Optima battery yesterday,and installed it temporary until i can get some way of taking up the extra space in the box.The blinkers do now work again and the wipers are fine,but the horn is still a no go even with me manually closing the contacts on the relay.I guess i have to dig deeper.
0.026925086975098 seconds processing time
