Thread: b2200-b2600
majesto1016
posted February 06, 2003 07:19 PM |
b2200-b2600
i know this doesnt have anything to do with rotary but this is the closet i could get to mazda truck forum anyway i have a b2200 i just wrecked :( the engine works perfectly fine and i have a friend that has a b2600 my question is will my b2200 engine fit in a b2600 pickup they both have manual tranny his has 4x4 if it even matters once again sorry but i have no where else to turn any help would be greatly apreciated
posted February 07, 2003 11:47 AM |
That engine should fit in his pickup.. The tranny might not bolt up but you might be able to swap the bellhousings.. Why would you want to put your 2200 in a 2600 truck, does his have no engine? or is it messed up.. The B2600 makes more power than your b2200, maybe you could fix the other engine..
straightrepu
posted February 07, 2003 11:48 AM |
b2200-b2600
It will fit, however the 2.6 could barely pull the 4x4, if
your were to put in the 2.2 you would not have enough power
to go 4 wheeling.If both engines are carbureted not to hard,
if they are fuel injected you spend countless hours trying
to swap everthing over. Better to find a b2200 that needs a
motor.
74 restorepu
majesto1016
posted February 07, 2003 03:11 PM |
quote ::Why would you want to put your 2200 in a 2600:: cuz i wrecked my b2200 and my find has a b2600 that needs the top end rebuilt so i thought hey maybe i could put my engine in it and have 4x4 lol
posted February 07, 2003 10:25 PM |
Edited By: Jeff20B on 7 Feb 2003 22:27
majesto1016
posted February 08, 2003 09:04 AM |
its an 87 2600 mines an 89 2200 thats a really good idea i just wish i had the money for it i was thinkin about doin it to mine before i wrecked it but now im just tryin to get back on the road how r those rotary pickups what can they do 0-60 they obviously have to be a hell lot faster than the 4 banger shit my riding lawn tractor is faster than my b2200 lol
posted February 08, 2003 10:34 AM |
Riding Lawn Mower...
I've heard about those lawn mower racers...too bad they're restricted to a briggs engine block! Can just imagine a 10A racing mower...! (Or even a rotary powered kart for the seriously deranged!)
posted February 08, 2003 11:54 AM |
0 to 60 I'm sure will be way better than the boinger.
Atkins builds single rotor 13Bs that would probably do really well on a riding lawn mower. Speaking of a 10A, I'm seriously considering rebuilding my '73 12A which is the spitting image of a 10A, other than the slightly wider rotor housings. But a 10A would be cool for the novelty of it all. Speaking of novelty, well, I'll just see how the rebuild goes with a set of '83-'85 12A rotors, which were the lightest unmodified rotors available, instead of the clunky old dual side seal type, and an auto rear counterweight I plan to use (something the old RX-2 engines never had). Hmm, I wonder if someone could build some 10A rotors with better seals etc?
majesto1016
posted February 08, 2003 01:31 PM |
shit i wish they made rotary shifter karts that would be some shit well.....unless u crashed into a wall
majesto1016
posted February 08, 2003 02:10 PM |
whoa
ok i found another friend that has an 87 b2000 with a dead engine will my 89 b2200 engine fit in that? sorry to drag this on but im tryin to get my little shit truck back on the road lol
http://www.geocities.com/majesto1016/
posted February 09, 2003 06:21 PM |
You didn't mention that the 2600 needed a rebuilt top end on the first post.. So sorry if that seemed a bit rude.. Anyways like someone else mentioned, the B2600 that your buddy has is carbed, and it has only about 110-120HP.. A B2200 engine has only about 70-80HP.. so it would struggle pushing all that extra weight and strain of the 4X4.. That engine will fit a b2000 though and the tranny is the same one so you should have no problem..
majesto1016
posted February 09, 2003 06:38 PM |
omg only 80hp hahahahaha i knew it was sad but damn thats saaaaadddddd lol
posted February 09, 2003 08:34 PM |
