Thread: Shocks
Xp882
posted October 08, 2011 02:53 PM |
Shocks
What's everyone running for shocks? Thinking about going with the kyb's any advice? Or going with the menroes with 50off
TimPA136
posted October 08, 2011 03:01 PM |
quote: What's everyone running for shocks? Thinking about going with the kyb's any advice?
KYBs were on my truck when I bought it years ago and feel great and havent seeped a drop yet, I would recommend them .
Xp882
posted October 08, 2011 03:12 PM |
Are they for performance or just a stock replacement.. I'm wanting a more performance shock and maybe something better for a lowered truck
TimPA136
posted October 08, 2011 04:04 PM |
Are they for performance or just a stock replacement ?
Only a guess, they were a low pressure gas, stock replacement.
top1usa
posted October 09, 2011 10:05 PM |
quote: What's everyone running for shocks? Thinking about going with the kyb's any advice? Or going with the menroes with 50off
I think Brad mentioned Blistens shocks were pretty good.
74' Mazda Repu-Flare
yellow
85' Toyota ae86-Red-SOLD
88' Toyota ae92-Gray
14' Toyota Prius
Mazdamark
posted October 12, 2011 03:08 PM |
I run the tokicos... Nice, taught ride...
94 RX7
89 RX7 GTUs
85 GSLSE
88 323 GTX
1975 REPU
posted October 13, 2011 05:22 PM |
The KYB GR-2 low end model is a cheap but poor choice. They don't last long and sag. This is the typical stock replacement shock. They are silver in color.
Monroe Matic are similar to the GR-2 and are a royal blue in color.
Monroe Sensa-Trac are a position sensative adjustable valve shock. Soft for the first 2 inches of travel but stiffen up after that to help reduce lean. I really like them on my other cars but they just don't last long on the REPU. Not made for a 512 lb front spring. Rebound goes to crap, they compess but don't or VERY slowly decompress.
KYB Gas-A-Just are a stiffer shock and more performance oriented and more likely to be able to handle a 512lb REPU front spring. White in color. Damn Good shock.
Tokico Blues are similar to the Gas-A-Just and are blue in color.
I don't know of a Tokico Illumina fitting REPU but it the Illumina's can't handle more than 375lb spring so it's moot.
Bilstein HD (Heavy-Duty) are excellent and are performance oriented. They can handle a REPU front spring.
If you buy a front shock for a first generation Camaro (67-69) you can make it fit the front of a REPU by enlarging the center hole of the lower control arm a few mm, and ovaling the shock's lower mounts inward a few mm. This greatly opens up your shock choices. I think it's a shorter shock too which reduces bottoming.
top1usa
posted October 13, 2011 09:41 PM |
Blistein's....
quote: The KYB GR-2 low end model is a cheap but poor choice. They don't last long and sag. This is the typical stock replacement shock. They are silver in color.
Brad,
Do you have a stock number or part number on those Blistein's and name of store where you purchased them from? What about the rear shocks...what are you using for them?
yellow
14' Toyota Prius
posted October 14, 2011 12:49 PM |
Top1usa
posted October 14, 2011 01:42 PM |
quote: Bilstein Shock info here:
http://mazdarepu.com/board/viewthread.php3?FID=8&TID=2024
I use Monroe air shocks in the back. Couldn't find a good high performance shock due to the length and the way it mounts. Old mustang was close.
Thanks for that Brad!!
yellow
14' Toyota Prius
freakinfred75
posted October 15, 2011 10:09 AM |
Lowering front end
Brad did you lower the front end and if so how?
dhood
posted October 15, 2011 11:11 AM |
I put 4 KYB A shocks on about 10 or 12 years ago, and tried replacing them with the Monroe matic 6 years later, but they was just too soft so put the KYBs back on. They have lasted a long long time, about 100 k miles so far. But now I either need new springs or shock replacements. I have some Tokicos ready to go when I lower my truck. I have a 77 with ac. Having that compressor makes a difference what shock you use.
posted October 17, 2011 11:26 AM |
quote: Brad did you lower the front end and if so how?
Yes. I used coilovers. I sell them $300 cash pick up or $335 paypal shipped. If you want to buy in person @ SevenStock let me know so I can order the springs.
http://www.mazdarepu.com/board/viewthread.php3?FID=6&TID=2684
77repu23
posted December 01, 2011 06:53 PM |
Hey Brad i'd like to purchase everything but the springs as I'd like to use my '77 stockers... Is that possible?
Thanks in advance.
posted December 02, 2011 09:12 PM |
quote: Hey Brad i'd like to purchase everything but the springs as I'd like to use my '77 stockers... Is that possible?
Thanks in advance.
Hello,
Are you saying you'd like to purchase the threaded spring perches I sell and use them with your 77 springs? If so that won't work since the diameter top of the stock springs is larger and won't seat into the threaded spring perch.
Unless I misunderstood in which case please clarify so we can discuss.
