$60, at least 6 runs, great club. Run by Ventura County Corvairs. Lunch included. Email me if you're going so I can email you the enrollment form and waiver.
Hope to see you there. Brad.
It was a fun time. The truck did okay. I need to find their posted times to compare. Chased tire pressures all day, never auto-x'd on this tire/rim setup. Ended up with 36.5psi front, 29 rear on my last run and it felt good. Finally would rotate thru the 180* sweeper at the far end of the track. I was understeering thru that most of the day.
Tire temps looked pretty even, need to fine tune the front camber as one side has more. I'll try to find some pics, there was a girl taking pics throughout the day. Met some good people, only other rotaries were some Rx-8's.
