Index > @ the Pickup Bed (General Topics) > Thread: Vin Locations?
bosozoku
posted March 19, 2011 03:40 AM
Vin Locations?
Just Bought my first REPU. i have a couple question. is there suppose to be a vin# on the driver side dash? or stamped onto the frame somewhere? only thing i could find are the a plates in the engine compartment and one in the door jam with the vin on it.
also which diffs would fit in my 74 so i could just cruz on the freeways?
thanks!
posted March 19, 2011 10:56 AM
There is the plate in the engine compartment, passenger side firewall.
The VIN is also stamped onto the frame rail. Drivers side, top of frame rail in the engine compartment. All the way forward. Under grit and grime typically.
posted March 19, 2011 11:00 AM
Ford courier has taller rear gears going all the way up to 3.60. You can still find these in the junkyard The 77 REPU has a 3.90.
A Torsen Gleasen limited slip differential will work with all of these with the spacer kit. Search 'Torsen' on this site and you'll find instructions to order from fuzzyeye and price.
I'd buy your 4.625 if it's in good shape.
bosozoku
posted March 19, 2011 01:18 PM
no vin# in the windshield area?
thanks for the info!
mattraver
posted March 19, 2011 03:37 PM
the diesels came with 3.30 gears and you can put the torsen in without a spacer
TimPA136
posted March 19, 2011 05:58 PM
off topic
See me on the cruise
bosozoku
posted March 19, 2011 10:34 PM
what would first gear be like with 3.30 diff..... and with 3.30 would i even want a torsen?
mattraver
posted March 20, 2011 11:52 PM
had the 330 gears w/torsen in my truck ,had to feather the clutch to take off but i got great gas milage .
0.024961948394775 seconds processing time
