Thread: heater hoses?
posted September 09, 2010 11:55 AM |
heater hoses?
Anyone have aftermarket part numbers for the three heater hoses?
Upper
Lower
From hardline to lower radiator
rotarydave
posted September 10, 2010 06:05 PM |
don't have them but I would love to have a set that actually go to the heater core.
TimPA136
posted September 11, 2010 01:36 PM |
quote: Anyone have aftermarket part numbers for the three heater hoses?
Upper
Lower
Hmmm.... I used a common GM molded hose as an emergency and cut off over 2 feet of straight unused hose from the end. It works fine but I suspect others can offer a better solution.
I will get the part number for that hose if needed.
Tim
mattraver
posted September 13, 2010 08:28 PM |
all i used was some 90 degree hoses and it looks stock they have a lot of different lengths in bulk 90 degree hose
posted September 14, 2010 05:44 PM |
Went with faux braided line from our friends @ Spectre Performance , $26.99 @ Manny, Moe and Jack. 3/4" size since where it hooks to the motor is 17.5mm, and the heater tube is 17mm. Both flanges on the heater valve in the cab are 14mm so had to crank it down good there.
5/8" is just a hair too large, didn't want to streach the hose.
posted September 14, 2010 06:47 PM |
oops. 5/8 = a hair too small
posted September 15, 2010 09:41 AM |
It's looking sweet Brad!
1974 Mazda Repu
1986 Yamaha RZ 500
1988 Yamaha YSR 50
1991 Suzuki RGV 250
1992 Yamaha TZR 250 SP
1996 Aprilia RS 250
2003 Ford F-450 6.0 Diesel
2004 Mazda RX8
2006 Yamaha Banshee
2014 18' Eclipse Toy Hauler
