Index > @ the Pickup Bed (General Topics) > Thread: thermo pellet in oil cooler
posted January 20, 2010 07:35 PM
Edited By: Brad on 20 Jan 2010 19:40
Thermo pellet in the oil cooler
In case you need to replace the thermo pellet (aka thermostat) that is in the oil cooler, it's part number is 8871-14-810. It includes the thermo pellet itself, the spring that sits on top of the pellet, the plug that threads under the oil cooler and an aluminum crush washer. For $87.03 from your friendly MAZDA dealer.
It bypasses below 140*F so the engine warms up faster, and if there's a pressure differential of 50psi from oil cooler inlet to outlet, it'll bypass too. Such as really cold oil.
Threebond 1194 is a bitchin' sealant for oil cooler fittings tooo....
Earl's Plumbing Stat-O-Seal 5/8" I.D. under the -10AN fittings. http://www.pegasusautoracing.com/productselection.asp?Product=3245
TimPA136
posted January 20, 2010 09:09 PM
Oil Cooler mounts
Brad,
A great replacement of broken oil cooler mounts are on many late model General Motors Air Injection Pump mounts.
Seeing your oil cooler and thermal pellet seemed like a good time to mention it.
I bought genunine Mazda mounts many years ago and they might still be available from Mazda ,if not, GM has them.
posted January 21, 2010 08:43 AM
Thanks Tim. I have some aftermarket generic ones that work well. More rubber than the mazda ones.
0.024211168289185 seconds processing time
